Implementation of a new Resource Sharing Protocol
Mon Nov 12 10:43:04 UTC 2018
Hello Malte,
On 12/11/2018 11:28, Malte Münch wrote:
> Hi,
> i am implementing a new resource sharing protocol for RTEMS as part of
> my bachelor thesis. The thesis is about resource sharing protocols in
> realtime environments on multicore systems. Right now i have to use a
> spinlock for a protocol and found a helpful implementation/function in
> cpukit/include/rtems/score/smplockmcs.h. My protocol requires the
> calling task to be non-preemptable and the comment for the
> acquire-function requires me to disable the interrupts.
the lock API for the operating system implementation is defined in
<rtems/score/isrlock.h>. Please do not use <rtems/score/smplock*.h>
directly.
> The comment in cpukit/rtems/src/taskmode.c says that it is not possible
> to change either interrupt levels or the preemptability of a task in a
> SMP configuration. Do you have a pointer for me on how to overcome this
> issue?
You look at the wrong layer. This rtems_task_mode() is a part of the
user API. It should not be used for the operating system implementation
which deals with locking protocols.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
