[rtems-tools commit] python: Provide support to select a valid python version.
Mon Nov 12 11:07:30 UTC 2018
On 12/11/2018 12:01, Chris Johns wrote:
>> On 12 Nov 2018, at 7:54 pm, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>>> On 08/11/2018 23:58, Chris Johns wrote:
>>> Module:    rtems-tools
>>> Branch:    master
>>> Commit:    e058db02816d7729e7cfa898522a6073f5d7e714
>>> Changeset: http://git.rtems.org/rtems-tools/commit/?id=e058db02816d7729e7cfa898522a6073f5d7e714
>>> Author:    Chris Johns <chrisj at rtems.org>
>>> Date:      Wed Nov  7 14:55:20 2018 +1100
>>> - Update imports after wrapping the code.
>>> - Fix python3 issues.
>>> - Fix config path issues for in repo and install runs.
>>> Closes #3537
>> After this commit the rtems-test no longer works on my machine. All tests ends up in a timeout:
>> rtems-test --rtems-bsp=erc32 --rtems-tools=/build/rtems/5 /build/git-build/b-erc32/
> What about erc32-run?
It behaves differently, but there are still timeouts:
rtems-test --rtems-bsp=erc32-run --rtems-tools=/build/rtems/5
RTEMS Testing - Tester, 5.0.not_released
  Command Line: /build/rtems/5/bin/rtems-test --rtems-bsp=erc32-run
  Python: 3.6.5 (default, Mar 31 2018, 19:45:04) [GCC]
Host: Linux-4.12.14-lp150.12.25-default-x86_64-with-glibc2.3.4 (Linux
huber-nb-linux.suse 4.12.14-lp150.12.25-default #1 SMP Thu Nov 1
06:14:23 UTC 2018 (3fcf457) x86_64 x86_64)
[  2/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_hello.exe
[  3/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_nsecs.exe
[  7/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp03.exe
[  6/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp02.exe
[  4/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_ticker.exe
[ 11/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp07.exe
[  5/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp01.exe
[ 10/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp06.exe
[  9/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp05.exe
[  8/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp04.exe
[  1/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_base_sp.exe
[ 12/694] p:0   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp08.exe
[ 14/694] p:6   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp11.exe
[ 13/694] p:6   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp09.exe
[ 15/694] p:6   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp12.exe
[ 18/694] p:6   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp15.exe
[ 17/694] p:6   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp14.exe
[ 16/694] p:6   f:0   u:0   e:0   I:0   B:0   t:0   i:0   W:0   |
sparc/erc32: ada_sp13.exe
[ 19/694] p:6   f:0   u:0   e:0   I:0   B:0   t:1   i:0   W:0   |
sparc/erc32: ada_sp16.exe
Result: timeout    Time: 0:03:00.250565 ada_ticker.exe
=>  run: /build/rtems/5/bin/sparc-rtems5-run
/build/git-build/b-erc32/sparc-rtems5/c/erc32/testsuites/ada/samples/ticker/ada_ticker.exe
=>  test start: ADA TICKER
] *** BEGIN OF TEST ADA TICKER ***
] *** TEST VERSION: 5.0.0.9b55081eb6c686e3b5fde13e6c84e021639317d3
] *** TEST STATE: EXPECTED-PASS
] *** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
] *** TEST TOOLS: 7.3.0 20180125 (RTEMS 5, RSB
30da0c720b78eba16a3f5272206c07415368617b, Newlib
2ab57ad59bc35dafffa69cd4da5e228971de069f)
] TA1 - clock_get -  9: 0: 0   12/31/1988
] TA2 - clock_get -  9: 0: 0   12/31/1988
] TA3 - clock_get -  9: 0: 0   12/31/1988
] TA1 - clock_get -  9: 0: 5   12/31/1988
] *** TIMEOUT TIMEOUT
Result: timeout    Time: 0:03:00.233552 ada_sp01.exe
/build/git-build/b-erc32/sparc-rtems5/c/erc32/testsuites/ada/sptests/sp01/ada_sp01.exe
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
