[PATCH 1/2] Coverage: add the style and js files to the symbol-set report directory
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Nov 14 18:49:25 UTC 2018
On Wed, 7 Nov 2018 at 13:11, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> tester/rt/coverage.py | 17 ++++-------------
> 1 file changed, 4 insertions(+), 13 deletions(-)
> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
> index 978a8c4..cfac464 100644
> --- a/tester/rt/coverage.py
> +++ b/tester/rt/coverage.py
> @@ -201,23 +201,14 @@ class report_gen_html:
> index_content = self._prepare_index_content(partial_reports)
> self._create_index_file(head_section,index_content)
> - def add_covoar_src_path(self):
> + def add_covoar_css(self):
> table_js_path = path.join(self.covoar_src_path, 'table.js')
> covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
> for symbol_set in self.symbol_sets:
> symbol_set_dir = path.join(self.build_dir,
> self.bsp + '-coverage', symbol_set)
> - html_files = os.listdir(symbol_set_dir)
> - for html_file in html_files:
> - html_file = path.join(symbol_set_dir, html_file)
> - if path.exists(html_file) and 'html' in html_file:
> - with open(html_file, 'r') as f:
> - file_data = f.read()
> - file_data = file_data.replace('table.js',
> table_js_path)
> - file_data = file_data.replace('covoar.css',
> - covoar_css_path)
> - with open(html_file, 'w') as f:
> - f.write(file_data)
> + path.copy_tree(covoar_css_path, symbol_set_dir)
> + path.copy_tree(table_js_path, symbol_set_dir)
> class build_path_generator(object):
> @@ -402,7 +393,7 @@ class coverage_run(object):
> self.rtdir,
> self.macros['bsp'])
> report.generate()
> - report.add_covoar_src_path()
> + report.add_covoar_css()
> def _cleanup(self):
> if not self.no_clean:
> 2.17.2
> ping :)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181115/506d3ea8/attachment.html>
