RTEMS 5 Release Branching
Fri Nov 16 02:09:49 UTC 2018
On 16/11/2018 08:29, Joel Sherrill wrote:
> I know the technical answer is "when all the tickets are closed" but
> can we put a firmer answer on this?
We need to wait for FreeBSD 12 to release then some time after for any changes
to libbsd to happen.
I need to modify the RSB to fetch all source not just the host I run the release
fetch on. We need to fetch and capture all source for all hosts. This is a
tricky problem and I am not yet sure how I will do this.
> Chris and I pushed to close tickets a few weeks ago while we were
> together at the mentor summit. But there are still more.
The FreeBSd release is 4 Dec 2018 and this leaves us only a few weeks before the
end of the year. We might be able to make a release but it will be tight.
> What can we do to push this release out?
I have made the ticket #2962 [1] a blocker. We need to have a baseline for the
BSPs and the testing environment we use. We will ship with some tests that are
not working, that is a fact of life, so lets flag these so users can see what is
expected to work and what is not expected to work.
[1] https://devel.rtems.org/ticket/2962
