[PATCH] score: Remove support for RTEMS_USE_16_BIT_OBJECT
Sat Nov 17 01:02:55 UTC 2018
On 16/11/18 5:08 pm, Sebastian Huber wrote:
> The RTEMS_USE_16_BIT_OBJECT define is not set by an RTEMS port.  Remove
> support for 16-bit object identifiers.  If someone really wants to use
> RTEMS on a 16-bit target, then it is better to use self-contained
> objects instead of playing around with object identifier optimizations.
Are self-contained threads supported?
