Improve English for source code (GCI'18) --- Patch file.
mehr sachal
mehrsachal at gmail.com
Sun Nov 18 07:33:53 UTC 2018
Kindly find the attached patch file required for the task:
https://codein.withgoogle.com/dashboard/task-instances/4863083462787072/
I have edited the following file:
https://github.com/RTEMS/rtems/blob/master/bsps/m68k/mvme167/README
Regards,
Mehr Mohammad Sachal
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181118/3cac6cd2/attachment-0001.html>
From 77c87341df5875782d9faa738b38900146fb5f82 Mon Sep 17 00:00:00 2001
Date: Sun, 18 Nov 2018 12:26:49 +0500
Subject: [PATCH] Improve English (GCI'18)
bsps/m68k/mvme167/README | 36 ++++++++++++++++++------------------
1 file changed, 18 insertions(+), 18 deletions(-)
diff --git a/bsps/m68k/mvme167/README b/bsps/m68k/mvme167/README
index 886ee7cc2c..4bdce9445d 100644
--- a/bsps/m68k/mvme167/README
+++ b/bsps/m68k/mvme167/README
@@ -33,7 +33,7 @@ Public License along with RTEMS; see file COPYING. If not, write to
the Free Software Foundation, 675 Mass Ave, Cambridge, MA 02139, USA.
Under no circumstances will the National Research Council of Canada
-nor Her Majesty the Queen in right of Canada assume any liablility
+nor Her Majesty the Queen in right of Canada assume any liability
for the use this software, nor any responsibility for its quality or
its support.
@@ -131,7 +131,7 @@ Floating-point
The MC68040 has a built-in FPU. This FPU does not implement all the
instruction of the MC68881/MC68882 floating-point coprocessors in
-hardware. The -m68040 compilation options instructs gcc to not generate
+hardware. The -m68040 compilation options instruct gcc to not generate
the missing instructions. All of the RTEMS code is built this way. Some
of the missing functionality must be supplied by external libraries. The
required functions are part of libgcc.a.
@@ -175,7 +175,7 @@ size of the executable by about 60KB and that it relies on run time
exceptions.
If your application does not do any floating-point operations at all, you
-should consider disabling the FPSP. In bsp_start(), emove the call to
+should consider disabling the FPSP. In bsp_start(), remove the call to
M68KFPSPInstallExceptionHandlers(), and uncomment the three lines in
mvme167.cfg that redefine which variants of libc, libm and libgcc to link
against.
@@ -188,7 +188,7 @@ If Jumper J1-4 is installed, certain configuration parameters may be read from
the first 31 bytes of User Area NVRAM starting at 0xFFFC0000. In this case, the
remaining J1-[5-7] jumpers are ignored, and the user is responsible for writing
the appropriate values in NVRAM (via 167-Bug) in order to alter the default
-behaviour. A zero value in NVRAM results in the default behaviour. The paramaters
+behaviour. A zero value in NVRAM results in the default behaviour. The parameters
that are configurable and their default settings are described below.
Cache Mode (0xFFFC0000 - 1 byte)
@@ -227,7 +227,7 @@ that are configurable and their default settings are described below.
10 - /dev/tty2, Serial Port 3 on the MVME712M.
11 - /dev/tty3, Serial Port 4 on the MVME712M.
If the printk port is the same as some other port that will be opened by an
- RTEMS application, then the driver must use polled I/O, or the printk port
+ RTEMS application, then the driver must use polled I/O or the printk port
must not be used.
IP Address (0xFFFC0004 - 4 bytes)
@@ -258,10 +258,10 @@ that are configurable and their default settings are described below.
reserved for future use
-Cache Control and Memory Mapping
+Cache-Control and Memory Mapping
-If configuration is not obtained from non-volatile RAM (ie. J1-4 is off),
+If the configuration is not obtained from non-volatile RAM (ie. J1-4 is off),
cache control is done through the remaining J1 jumpers as follows:
If Jumper J1-7 is installed, the data cache will be turned on. If Jumper
@@ -280,16 +280,16 @@ non-existent memory. Caching is not controllable on a finer grain.
Networking
the networking parameters shown above must be specified in an initialized
rtems_bsdnet_ifconfig struct. This structure is declared and initialized to
specify any network devices and includes entries for ip_address, ip_netmask
and hardware_address. See the Network Device Configuration section of the
RTEMS Networking Supplement.
-When non-default (non-zero) networking paramaters are provided in NVRAM (ie.
+When non-default (non-zero) networking parameters are provided in NVRAM (ie.
j1-4 is on), the user MUST ensure that the corresponding entries in the
-ifconfig struct are NULL. Failing to do so is an error, because it causes
+ifconfig struct are NULL. Failing to do so is an error because it causes
the memory allocated for the initialized struct values to be lost.
@@ -324,12 +324,12 @@ and the Cygnus Cygwin32 release b20.1 environment, with the following tools:
- GNU binutils 2.9.4 configured for a i586-cygwin32 host and m68k-rtems
target;
-With the latter environment, be patient; builds take a very looong time...
+With the latter environment, be patient; builds take a very long time...
Current development is done on a Pentium III PC running RedHat Linux 6.1.
At the time this README was composed, the latest working compiler that was
used successfully was gcc version 2.96 20000213 (experimental). Both the C
-and C++ compilers were working. Binutils 2.10 are used.
+and C++ compilers were working. Binutils 2.10 is used.
Known Problems
@@ -337,8 +337,8 @@ Known Problems
Polled I/O without termios may not work very well on input. The problem
is that input processing is not done: applications may get characters too
-early, and may get characters that they normally would not get, such as
-backspace or delete. Furthermore, input is not buffered at all. The latest
+early and may get characters that they normally would not get, such as
+backspace or delete. Furthermore, the input is not buffered at all. The latest
versions of rtems seem to set the count field in the rtems_libio_rw_args_t
argument to the buffer size, not to the number of characters expected on
input. Rather than wait for 1024 characters on each call, the driver
@@ -346,7 +346,7 @@ returns each character when it is received.
The cdtest will not run with interrupt-driven I/O. The reason is that the
constructors for the static objects are called at boot time when the
-interrupts are still disabled. The output buffer fills up, but never empties,
+interrupts are still disabled. The output buffer fills up but never empties,
and the application goes into an infinite loop waiting for buffer space. This
should have been documented in the rtems/c/src/tests/PROBLEMS file. The moral
of this story is: do not do I/O from the constructors or destructors of static
@@ -365,16 +365,16 @@ a way to detect whether characters are still in the FIFO and to wait for them
to be transmitted.
The first raw buffer to be transmitted after the console is re-initialized
-with tcsetattr() is garbled. At this time, it does not seem worth while to
+with tcsetattr() is garbled. At this time, it does not seem worthwhile to
track this problem down.
In the stackchk test, an access fault exception is raised after the stack is
-blown. This is one case were overwritting the first or last 16 bytes of the
+blown. This is one case were overwriting the first or last 16 bytes of the
stack does cause problems (but hey, an exception occurred, which is better
than propagating the error).
