[PATCH] arm: Use bl for the boot_start_hook_0 calls to avoid JUMP11 calls.
chrisj at rtems.org chrisj at rtems.org
Tue Nov 20 09:32:16 UTC 2018
 bsps/arm/shared/start/start.S | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/bsps/arm/shared/start/start.S b/bsps/arm/shared/start/start.S
index e4df46f656..f9f2baec32 100644
--- a/bsps/arm/shared/start/start.S
+++ b/bsps/arm/shared/start/start.S
@@ -302,7 +302,7 @@ bsp_start_skip_hyp_svc_switch:
 	mov	r1, r5		/* machine type number or ~0 for DT boot */
 	mov	r2, r6		/* physical address of ATAGs or DTB */
-	b	bsp_start_hook_0
+	bl	bsp_start_hook_0
 bsp_start_hook_0_done:
@@ -406,7 +406,7 @@ _start:
 	ldr	sp, =_ISR_Stack_area_end
 	ldr	lr, =bsp_start_hook_0_done + 1
2.14.1
