qemu command line for arm zynq
    Chris Johns
    chrisj at rtems.org
    Wed Nov 21 04:04:10 UTC 2018
On 21/11/2018 13:24, Joel Sherrill wrote:
> On Tue, Nov 20, 2018, 8:10 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org> wrote:
>     Hi,
>     I have tracked down the issue I am having with an RSB qemu on FreeBSD with the
>     xilinx_zynq_a9_qemu BSP. It is ...
>     https://git.rtems.org/rtems-tools/tree/tester/rtems/testing/qemu.cfg#n51
>     FreeBSD needs the commented line and I assume Linux works with the
>     uncommented line.
>     Could someone on Linux please let me know if the commented line works?
>     I would prefer a common command line if possible before I explore variants of
>     the command line to use.
> It depends on the version of qemu. I don't recall when it changed but it seems
> that distros include a qemu that takes one and our git rsb takes another.
OK and thanks. I suppose we should have rtems-test support the RSB built qemu.
> At least that's what I recall. I have the same kind of commented lines in the
> sim-scripts
A configuration option could be added but I am not sure what is should be
called. It could `qemu_console_serial`?
