[PATCH] score: Remove support for RTEMS_USE_16_BIT_OBJECT
Wed Nov 21 06:50:08 UTC 2018
On 17/11/2018 02:02, Chris Johns wrote:
> On 16/11/18 5:08 pm, Sebastian Huber wrote:
>> The RTEMS_USE_16_BIT_OBJECT define is not set by an RTEMS port.  Remove
>> support for 16-bit object identifiers.  If someone really wants to use
>> RTEMS on a 16-bit target, then it is better to use self-contained
>> objects instead of playing around with object identifier optimizations.
> Are self-contained threads supported?
Do you want to keep this stuff? The 16-bit architectures are not really
a success story with RTEMS.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
