[PATCH] score: Remove support for RTEMS_USE_16_BIT_OBJECT
Wed Nov 21 06:58:43 UTC 2018
> On 21 Nov 2018, at 5:50 pm, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 17/11/2018 02:02, Chris Johns wrote:
>>> On 16/11/18 5:08 pm, Sebastian Huber wrote:
>>> The RTEMS_USE_16_BIT_OBJECT define is not set by an RTEMS port.  Remove
>>> support for 16-bit object identifiers.  If someone really wants to use
>>> RTEMS on a 16-bit target, then it is better to use self-contained
>>> objects instead of playing around with object identifier optimizations.
>> Are self-contained threads supported?
> Do you want to keep this stuff? The 16-bit architectures are not really a success story with RTEMS.
No and sorry about the confusion. I was just responding to the comment about using self-contained object except thread are not yet supported.
RIP 16bit ids.
