[PATCH v3] Add LICENSE.BSD-2-Clause
Fri Nov 23 06:55:44 UTC 2018
Copied from:
https://spdx.org/licenses/BSD-2-Clause.html
The formatting is suitable for C/C++ source comments.
Update #3053.
 LICENSE.BSD-2-Clause | 39 +++++++++++++++++++++++++++++++++++++++
 1 file changed, 39 insertions(+)
 create mode 100644 LICENSE.BSD-2-Clause
diff --git a/LICENSE.BSD-2-Clause b/LICENSE.BSD-2-Clause
new file mode 100644
index 0000000000..d19f31e646
--- /dev/null
+++ b/LICENSE.BSD-2-Clause
@@ -0,0 +1,39 @@
+https://spdx.org/licenses/BSD-2-Clause.html
+This license file serves as a template for the license header in files.
+You are the copyright holder.  Copy to comment below the top of the file in
+which you want to use this license for your contribution.  Replace the
+<FIRST YEAR> placeholder with the year of your first substantial contribution
+to this file.  Update the <LAST YEAR> with the year of your last substantial
+contribution to this file.  If the first and last years are the same, then
+remove the <LAST YEAR> placeholder with the comma.  Replace the
+<COPYRIGHT HOLDER> placeholder with your name.  You must not alter anything
+else in the license comment.
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) <FIRST YEAR>, <LAST YEAR> <COPYRIGHT HOLDER>
+ * are met:
2.16.4
