rtems-test error with coverage
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Nov 23 08:32:55 UTC 2018
Hi,
I was trying to run coverage with rtems-test on a fresh install, and faced
the following errors. This is strange as everything was working and I can't
figure out what went wrong.
Also, I don't see covoar executable in the covoar/ directory.
I'm using Python 2.7.15
Traceback (most recent call last):
File "/home/lunatic/development/rtems/rtems-tools/tester/rt/coverage.py",
line 263, in parse
ss = ss.replace('@BSP@', self.bsp_name)
TypeError: a bytes-like object is required, not 'str'
During handling of the above exception, another exception occurred:
line 376, in run
symbol_sets = parser.parse()
line 268, in parse
raise error.general('Symbol set parsing failed for %s' % (sset))
rtemstoolkit.error.general: error: Symbol set parsing failed for score
File "/home/lunatic/development/rtems/rtems-tools/tester/rt/cmd-test.py",
line 42, in <module>
test.run(sys.argv[1:], command_path = base)
File "/home/lunatic/development/rtems/rtems-tools/tester/rt/test.py",
line 384, in run
coverage_runner.run()
line 386, in run
self._cleanup();
line 406, in _cleanup
os.remove(self.symbol_select_path)
FileNotFoundError: [Errno 2] No such file or directory:
'/home/lunatic/development/rtems/rtems-tools/tester/rtems/testing/coverage/leon3-qemu-symbols.ini'
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181123/a398d877/attachment-0001.html>
