The T Test Framework
Fri Nov 23 10:31:17 UTC 2018
Hello,
I had a bit of time to work on a new test framework for RTEMS:
https://devel.rtems.org/ticket/3199
You can find a draft of the documentation here:
https://devel.rtems.org/attachment/ticket/3199/contributor.pdf
You can find a prototype implementation here:
https://devel.rtems.org/attachment/ticket/3199/t.tar.gz
The test framework runs on FreeBSD, MSYS2, Linux and RTEMS. So it would
be possible to run POSIX API tests on multiple platforms.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
