rtems-test error with coverage
Fri Nov 23 22:20:36 UTC 2018
On 24/11/18 12:50 am, Vijay Kumar Banerjee wrote:
> On Fri, 23 Nov 2018 at 16:21, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 23 Nov 2018, at 8:55 pm, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>     <mailto:vijaykumar9597 at gmail.com>> wrote:
>>     On Fri, 23 Nov 2018 at 15:09, Chris Johns <chrisj at rtems.org
>>         On 23/11/18 7:32 pm, Vijay Kumar Banerjee wrote:
>>         > Hi,
>>         > I was trying to run coverage with rtems-test on a fresh install, and
>>         faced
>>         > the following errors. This is strange as everything was working and
>>         I can't
>>         > figure out what went wrong.
>>         > Also, I don't see covoar executable in the covoar/ directory.
>>         > I'm using Python 2.7.15
>>         Are you sure? The latest version selects the python used.
>>     `python --version` returns 2.7.15
>     The python command may not be used. It could python3.
>>         If you do ...
>>          $ export RTEMS_PYTHON_OVERRIDE=python2
>>         ... does it work?
>>     Yes, this worked. Now I see
>>     error: coverage: covoar not found
>     I am not sure about this error but it does mean there maybe some issues with
>     python3.
> For some reason, the covoar executable is not installed in the tester/covoar
> directory, where the the script is searching for it.
OK.
> The covoar is installed in the bin directory. Is there any reason that script
> searches for covoar in the tester/ instead of the bin directory?
Would anyone call 'covoar' directly?
If the answer is No then I suggest the waf script is updated to install covoar
into the tester directory. There should be examples in the script to do this. I
am fine with this happening.
