rtems-test error with coverage
Chris Johns
chrisj at rtems.org
Fri Nov 23 23:29:41 UTC 2018
> On 24 Nov 2018, at 10:07 am, Joel Sherrill <joel at rtems.org> wrote:
>> On Fri, Nov 23, 2018, 4:20 PM Chris Johns <chrisj at rtems.org wrote:
>> On 24/11/18 12:50 am, Vijay Kumar Banerjee wrote:
>> > On Fri, 23 Nov 2018 at 16:21, Chris Johns <chrisj at rtems.org
>> > <mailto:chrisj at rtems.org>> wrote:
>> > On 23 Nov 2018, at 8:55 pm, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>> > <mailto:vijaykumar9597 at gmail.com>> wrote:
>> >> On Fri, 23 Nov 2018 at 15:09, Chris Johns <chrisj at rtems.org
>> >> On 23/11/18 7:32 pm, Vijay Kumar Banerjee wrote:
>> >> > Hi,
>> >> > I was trying to run coverage with rtems-test on a fresh install, and
>> >> faced
>> >> > the following errors. This is strange as everything was working and
>> >> I can't
>> >> > figure out what went wrong.
>> >> > Also, I don't see covoar executable in the covoar/ directory.
>> >> > I'm using Python 2.7.15
>> >> Are you sure? The latest version selects the python used.
>> >> `python --version` returns 2.7.15
>> > The python command may not be used. It could python3.
>> >> If you do ...
>> >> $ export RTEMS_PYTHON_OVERRIDE=python2
>> >> ... does it work?
>> >> Yes, this worked. Now I see
>> >> error: coverage: covoar not found
>> > I am not sure about this error but it does mean there maybe some issues with
>> > python3.
>> > For some reason, the covoar executable is not installed in the tester/covoar
>> > directory, where the the script is searching for it.
>> OK.
>> > The covoar is installed in the bin directory. Is there any reason that script
>> > searches for covoar in the tester/ instead of the bin directory?
>> Would anyone call 'covoar' directly?
>> If the answer is No then I suggest the waf script is updated to install covoar
>> into the tester directory. There should be examples in the script to do this. I
>> am fine with this happening.
> There is no reason why it wouldn't be if any other application or library used it.
Yes and we can move it if there is a demand. It would need a lot of documentation to support it properly.
> But 5hey would have to use rtems-tester or a similar framework to drive it.
Yeap. The tester is a nice simple interface.
> For now, feel free to put it in tester/bin
OK, we just need a patch. :)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181124/ebe326af/attachment.html>
