[m68k/gen68340]Add per-section compilation and linking support
Shashvat Jain shashvatjain2002 at gmail.com
Sat Nov 24 21:07:26 UTC 2018
Hello ,
I just enabled the per-function and per-data element section support for
the gen68340 bsp in m68k architecture .
The patch for the change has been attached
Thank you :)
Regards
--Shashvat
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181125/a4136805/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181125/a4136805/attachment-0001.obj>
