[m68k/gen68340]Add per-section compilation and linking support
Joel Sherrill
joel at rtems.org
Sat Nov 24 23:01:31 UTC 2018
I built the BSP with and without the patch and verified that it looks good.
Size went down, entry point stayed the same. That's all we can check
without hardware. If it wasn't right, then the text size would be near 0. I
did that with the erc32 BSP when I did it as the first case. I added a
"closes #2573." to the end of the commit message. That closes the ticket
associated with this BSP working. This is the list of the remaining BSPs:
https://devel.rtems.org/ticket/2577\
This is now pushed.
Thanks.
--joel
On Sat, Nov 24, 2018 at 3:07 PM Shashvat Jain <shashvatjain2002 at gmail.com>
wrote:
> Hello ,
> I just enabled the per-function and per-data element section support for
> the gen68340 bsp in m68k architecture .
> The patch for the change has been attached
> Thank you :)
> Regards
> --Shashvat
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181124/1b4fc787/attachment-0001.html>
