[m68k/gen68360]Add per-section compilation and linking support
Joel Sherrill
joel at rtems.org
Sun Nov 25 15:33:29 UTC 2018
Should be OK now. Double check the ticket closed. :)
Thanks.
--joel
On Sun, Nov 25, 2018 at 1:58 AM Shashvat Jain <shashvatjain2002 at gmail.com>
wrote:
> I managed to do " git --amend " here is the updated patch with message
> "Closes #2566"
> thank you
> Regards
> --Shashvat
> On Sun, Nov 25, 2018 at 1:23 PM Shashvat Jain <shashvatjain2002 at gmail.com>
> wrote:
>> Hello ,
>> I just enabled the per-function and per-data element section support for
>> the gen68340 bsp in m68k architecture .
>> The patch for the change has been attached
>> anyone who pushes it , please add the message "Closes #2566"
>> I forgot to add it , also please tell me how to edit the message on a
>> commit which is in source tree .
>> Thank you :)
>> Regards
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181125/8e455228/attachment.html>
