BSP for Microchip ATSAMA5D27-SOM1-EK1
Thomas Dörfler thomas.doerfler at embedded-brains.de
Sun Nov 25 18:23:42 UTC 2018
Peter,
just to make you aware: we designed a board with the ATSAMV7 chip and hit some nasty and at least one really ugly bug: operating the USB interface concurrently with external SDRAM does not work. Half a year after reporting this bug, Microchip confirmed it, but did not plan any fix for it. BTW: The conbination (USB+SDRAM) was also available on Microchip's evaluation board, but obviously was not tested together at Microchips labs...
So: I recommend you to tripple check, whether the ATSAMA5 meets all of your expectations.
Kind regards,
Thomas.
----- Ursprüngliche Mail -----
Von: "Peter Dufault" <dufault at hda.com>
An: "Development" <devel at rtems.org>
Gesendet: Sonntag, 25. November 2018 18:38:19
Betreff: BSP for Microchip ATSAMA5D27-SOM1-EK1
I need to evaluate this for a multi-chip application.
This part is a result of Microchip’s take-over of ATMEL.  I’m double-checking that to create a BSP based on this I should start with the existing ATSAMV7 BSP, I think the peripherals (e.g. network chip and so on) are the same as the existing ATSAMV7 port.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
embedded brains GmbH
Thomas Doerfler
Dornierstr. 4
D-82178 Puchheim
Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18 94 741-12
Fax:   +49-89-18 94 741-09
PGP: Public key available on request.
