[PATCH v2 1/7] tester: Change the QEMU command line to match the RSB built QEMU.
chrisj at rtems.org chrisj at rtems.org
Mon Nov 26 00:56:19 UTC 2018
The command line changed and the RSB is the newer version. Make
the old version via a config variable.
 tester/rtems/testing/qemu.cfg | 7 +++++--
 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/qemu.cfg
index 52a3752..e37dc9b 100644
--- a/tester/rtems/testing/qemu.cfg
+++ b/tester/rtems/testing/qemu.cfg
@@ -51,8 +51,11 @@
 # Qemu common option patterns.
-%define qemu_opts_base   -no-reboot -monitor none -serial stdio -nographic
-#%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio -nographic
+%if %{defined qemu_use_serial_console}
+ %define qemu_opts_base -no-reboot -monitor none -serial stdio -nographic
+%else
+ %define qemu_opts_base -no-reboot -serial null -serial mon:stdio -nographic
+%endif
 %define qemu_opts_no_net -net none
2.14.1
