[PATCH] Remove rtems_cache_*_processor_set() functions
Mon Nov 26 13:09:21 UTC 2018
The following rtems_cache_*_processor_set() cache manager API functions
are exotic, complex, very hard to use correctly, not used in the RTEMS
code base, and apparently unused by applications.
Close #3622.
 bsps/shared/cache/cacheimpl.h         | 91 -----------------------------------
 cpukit/include/rtems/rtems/cache.h    | 79 ------------------------------
 testsuites/smptests/smpcache01/init.c | 52 +++-----------------
 3 files changed, 7 insertions(+), 215 deletions(-)
diff --git a/bsps/shared/cache/cacheimpl.h b/bsps/shared/cache/cacheimpl.h
index 7e9f863337..96dc3c0361 100644
--- a/bsps/shared/cache/cacheimpl.h
+++ b/bsps/shared/cache/cacheimpl.h
@@ -49,97 +49,6 @@
 #error "CPU_INSTRUCTION_CACHE_ALIGNMENT is greater than CPU_CACHE_LINE_BYTES"
 #endif
-#if defined(RTEMS_SMP)
-#include <rtems/score/smpimpl.h>
-typedef struct {
-  const void *addr;
-  size_t size;
-} smp_cache_area;
-#if defined(CPU_DATA_CACHE_ALIGNMENT)
-static void smp_cache_data_flush(void *arg)
-  smp_cache_area *area = arg;
-  rtems_cache_flush_multiple_data_lines(area->addr, area->size);
-static void smp_cache_data_inv(void *arg)
-  rtems_cache_invalidate_multiple_data_lines(area->addr, area->size);
-static void smp_cache_data_flush_all(void *arg)
-  rtems_cache_flush_entire_data();
-static void smp_cache_data_inv_all(void *arg)
-  rtems_cache_invalidate_entire_data();
-#endif /* defined(CPU_DATA_CACHE_ALIGNMENT) */
-void
-rtems_cache_flush_multiple_data_lines_processor_set(
-  const void *addr,
-  size_t size,
-  const size_t setsize,
-  const cpu_set_t *set
-  smp_cache_area area = { addr, size };
-  _SMP_Multicast_action( setsize, set, smp_cache_data_flush, &area );
-#endif
-void
-rtems_cache_invalidate_multiple_data_lines_processor_set(
-  const void *addr,
-  size_t size,
-  _SMP_Multicast_action( setsize, set, smp_cache_data_inv, &area );
-#endif
-void
-rtems_cache_flush_entire_data_processor_set(
-  _SMP_Multicast_action( setsize, set, smp_cache_data_flush_all, NULL );
-#endif
-void
-rtems_cache_invalidate_entire_data_processor_set(
-  _SMP_Multicast_action( setsize, set, smp_cache_data_inv_all, NULL );
-#endif
-#endif /* defined(RTEMS_SMP) */
  * THESE FUNCTIONS ONLY HAVE BODIES IF WE HAVE A DATA CACHE
diff --git a/cpukit/include/rtems/rtems/cache.h b/cpukit/include/rtems/rtems/cache.h
index 16157b26e6..1e62c4270b 100644
--- a/cpukit/include/rtems/rtems/cache.h
+++ b/cpukit/include/rtems/rtems/cache.h
@@ -284,85 +284,6 @@ void rtems_cache_coherent_add_area(
   uintptr_t area_size
-#if defined( RTEMS_SMP )
- * @brief Flushes multiple data cache lines for a set of processors
- * Dirty cache lines covering the area are transferred to memory.
- * Depending on the cache implementation this may mark the lines as invalid.
- * This operation should not be called from interrupt context.
- * @param[in] addr The start address of the area to flush.
- * @param[in] size The size in bytes of the area to flush.
- * @param[in] setsize The size of the processor set.
- * @param[in] set The target processor set.
-void rtems_cache_flush_multiple_data_lines_processor_set(
-  const void *addr,
-  size_t size,
- * @brief Invalidates multiple data cache lines for a set of processors
- * The cache lines covering the area are marked as invalid.  A later read
- * access in the area will load the data from memory.
- * In case the area is not aligned on cache line boundaries, then this
- * operation may destroy unrelated data.
- * @param[in] addr The start address of the area to invalidate.
- * @param[in] size The size in bytes of the area to invalidate.
-void rtems_cache_invalidate_multiple_data_lines_processor_set(
-  const void *addr,
-  size_t size,
- * @brief Flushes the entire data cache for a set of processors
- * @see rtems_cache_flush_multiple_data_lines().
-void rtems_cache_flush_entire_data_processor_set(
- * @brief Invalidates the entire cache for a set of processors
- * This function is responsible for performing a data cache
- * invalidate. It invalidates the entire cache for a set of
- * processors.
-void rtems_cache_invalidate_entire_data_processor_set(
-#endif
 #ifdef __cplusplus
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index c3e58685b2..131b986050 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -23,8 +23,6 @@
 const char rtems_test_name[] = "SMPCACHE 1";
-CPU_STRUCTURE_ALIGNMENT static int data_to_flush[1024];
 #define CPU_COUNT 32
 #define WORKER_PRIORITY 100
@@ -54,43 +52,12 @@ static void test_action( void *arg )
 typedef void ( *test_case )(
   size_t set_size,
-  const cpu_set_t *cpu_set,
-  SMP_barrier_State *bs
+  const cpu_set_t *cpu_set
-static void test_cache_flush_multiple_data_lines(
-  size_t set_size,
-  rtems_cache_flush_multiple_data_lines_processor_set( &data_to_flush,
-      sizeof(data_to_flush), set_size, cpu_set );
-static void test_cache_invalidate_multiple_data_lines(
-  size_t set_size,
-  rtems_cache_invalidate_multiple_data_lines_processor_set( &data_to_flush,
-static void test_cache_flush_entire_data(
-  size_t set_size,
-  rtems_cache_flush_entire_data_processor_set( set_size, cpu_set );
 static void test_cache_invalidate_entire_instruction(
   size_t set_size,
   rtems_cache_invalidate_entire_instruction();
@@ -98,8 +65,7 @@ static void test_cache_invalidate_entire_instruction(
 static void test_cache_invalidate_multiple_instruction_lines(
   size_t set_size,
   uint32_t self = rtems_get_current_processor();
@@ -126,8 +92,7 @@ static void broadcast_test_init( void )
 static void broadcast_test_body(
   size_t set_size,
   _SMP_Multicast_action( set_size, cpu_set, test_action, &ctx );
@@ -141,9 +106,6 @@ static void broadcast_test_fini( void )
 static test_case test_cases[] = {
-  test_cache_flush_multiple_data_lines,
-  test_cache_invalidate_multiple_data_lines,
-  test_cache_flush_entire_data,
   test_cache_invalidate_entire_instruction,
   test_cache_invalidate_multiple_instruction_lines,
   broadcast_test_body
@@ -158,7 +120,7 @@ static void call_tests( size_t set_size,
   for (i = 0; i < RTEMS_ARRAY_SIZE( test_cases ); ++i) {
     barrier( bs );
-    ( *test_cases[ i ] )( set_size, cpu_set, bs );
+    ( *test_cases[ i ] )( set_size, cpu_set );
     barrier( bs );
@@ -177,7 +139,7 @@ static void call_tests_isr_disabled( size_t set_size,
     _ISR_Local_disable( isr_level );
     barrier( bs );
     _ISR_Local_enable( isr_level );
     barrier( bs );
@@ -197,7 +159,7 @@ static void call_tests_with_thread_dispatch_disabled( size_t set_size,
     cpu_self = _Thread_Dispatch_disable();
     barrier( bs );
     barrier( bs );
     _Thread_Dispatch_enable( cpu_self );
2.16.4
