[PATCH 2/7] score: Remove Objects_Information::is_string
Mon Nov 26 13:12:09 UTC 2018
Use Objects_Information::name_length to store this information.
Update #3621.
 cpukit/include/rtems/score/objectimpl.h        | 33 +++++++++++++-------
 cpukit/posix/src/key.c                         |  3 +-
 cpukit/posix/src/mqueue.c                      |  1 -
 cpukit/posix/src/psxsemaphore.c                |  1 -
 cpukit/posix/src/ptimer.c                      |  3 +-
 cpukit/posix/src/shm.c                         |  1 -
 cpukit/rtems/src/barrier.c                     |  3 +-
 cpukit/rtems/src/dpmem.c                       |  3 +-
 cpukit/rtems/src/msg.c                         |  3 +-
 cpukit/rtems/src/part.c                        |  3 +-
 cpukit/rtems/src/ratemon.c                     |  3 +-
 cpukit/rtems/src/region.c                      |  3 +-
 cpukit/rtems/src/rtemstimer.c                  |  3 +-
 cpukit/rtems/src/sem.c                         |  3 +-
 cpukit/sapi/src/extension.c                    |  3 +-
 cpukit/score/src/objectgetnameasstring.c       |  2 +-
 cpukit/score/src/objectidtoname.c              |  2 +-
 cpukit/score/src/objectinitializeinformation.c |  4 +--
 cpukit/score/src/objectnamespaceremove.c       |  4 +--
 cpukit/score/src/objectnametoidstring.c        |  2 +-
 cpukit/score/src/objectsetname.c               | 43 +++++++++++++-------------
 cpukit/score/src/thread.c                      |  3 +-
 testsuites/psxtests/psxobj01/init.c            |  1 -
 23 files changed, 62 insertions(+), 68 deletions(-)
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index 8934e24244..4141183176 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -132,14 +132,17 @@ typedef struct {
   Objects_Maximum   inactive;
   /** This is the number of objects in a block. */
   Objects_Maximum   allocation_size;
-  /** This is the maximum length of names. */
+   * @brief This is the maximum length of names.
+   * A length of zero indicates that this object has a no string name
+   * (OBJECTS_NO_STRING_NAME).
   uint16_t          name_length;
   /** This field indicates the API of this object class. */
   uint8_t           the_api;
   /** This is the class of this object set. */
   uint8_t           the_class;
-  /** This is true if names are strings. */
-  bool              is_string;
   /** This is the true if unlimited objects in this class. */
   bool              auto_extend;
   /** This is the size in bytes of each object instance. */
@@ -225,14 +228,19 @@ void _Objects_Do_initialize_information(
   uint16_t             the_class,
   uint32_t             maximum,
   uint16_t             size,
-  bool                 is_string,
-  uint32_t             maximum_name_length
+  uint16_t             maximum_name_length
 #if defined(RTEMS_MULTIPROCESSING)
   Objects_Thread_queue_Extract_callout extract
 #endif
+ * @brief Constant for the object information string name length to indicate
+ * that this object class has no string names.
+#define OBJECTS_NO_STRING_NAME 0
  *  @brief Initialize object Information
@@ -261,7 +269,6 @@ void _Objects_Do_initialize_information(
     the_class, \
     maximum, \
     size, \
-    is_string, \
     maximum_name_length, \
     extract \
@@ -271,7 +278,6 @@ void _Objects_Do_initialize_information(
       the_class, \
       maximum, \
       size, \
-      is_string, \
       extract \
@@ -282,7 +288,6 @@ void _Objects_Do_initialize_information(
     the_class, \
     maximum, \
     size, \
-    is_string, \
     extract \
@@ -292,7 +297,6 @@ void _Objects_Do_initialize_information(
       the_class, \
       maximum, \
       size, \
-      is_string, \
       maximum_name_length \
 #endif
@@ -735,6 +739,13 @@ Objects_Maximum _Objects_Active_count(
   const Objects_Information *information
+RTEMS_INLINE_ROUTINE bool _Objects_Has_string_name(
+  const Objects_Information *information
+  return information->name_length > 0;
 RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Extend_size(
@@ -919,7 +930,7 @@ RTEMS_INLINE_ROUTINE void _Objects_Open_u32(
   uint32_t                   name
-  _Assert( !information->is_string );
+  _Assert( !_Objects_Has_string_name( information ) );
   the_object->name.name_u32 = name;
   _Objects_Set_local_object(
@@ -943,7 +954,7 @@ RTEMS_INLINE_ROUTINE void _Objects_Open_string(
   const char                *name
-  _Assert( information->is_string );
+  _Assert( _Objects_Has_string_name( information ) );
   the_object->name.name_p = name;
diff --git a/cpukit/posix/src/key.c b/cpukit/posix/src/key.c
index 71c202926e..a39e8d6479 100644
--- a/cpukit/posix/src/key.c
+++ b/cpukit/posix/src/key.c
@@ -142,8 +142,7 @@ static void _POSIX_Keys_Manager_initialization(void)
                                 /* maximum objects of this class */
     sizeof( POSIX_Keys_Control ),
                                 /* size of this object's control block */
-    false,                      /* true if names for this object are strings */
-    0,                          /* maximum length of each object's name */
+    OBJECTS_NO_STRING_NAME,     /* maximum length of each object's name */
     NULL                        /* Proxy extraction support callout */
diff --git a/cpukit/posix/src/mqueue.c b/cpukit/posix/src/mqueue.c
index e2c9b5f2b2..192d853c35 100644
--- a/cpukit/posix/src/mqueue.c
+++ b/cpukit/posix/src/mqueue.c
@@ -54,7 +54,6 @@ static void _POSIX_Message_queue_Manager_initialization(void)
     _Configuration_POSIX_Maximum_message_queues,
     sizeof( POSIX_Message_queue_Control ),
-    true,                       /* true if names for this object are strings */
     _POSIX_PATH_MAX,            /* maximum length of each object's name */
diff --git a/cpukit/posix/src/psxsemaphore.c b/cpukit/posix/src/psxsemaphore.c
index 9e259b8ea3..a26ba7563e 100644
--- a/cpukit/posix/src/psxsemaphore.c
+++ b/cpukit/posix/src/psxsemaphore.c
@@ -45,7 +45,6 @@ static void _POSIX_Semaphore_Manager_initialization(void)
     _Configuration_POSIX_Maximum_named_semaphores,
     sizeof( POSIX_Semaphore_Control ),
diff --git a/cpukit/posix/src/ptimer.c b/cpukit/posix/src/ptimer.c
index 9472cd49e5..f3af1710b8 100644
--- a/cpukit/posix/src/ptimer.c
+++ b/cpukit/posix/src/ptimer.c
@@ -65,8 +65,7 @@ static void _POSIX_Timer_Manager_initialization(void)
     _Configuration_POSIX_Maximum_timers,
     sizeof( POSIX_Timer_Control ),
+    OBJECTS_NO_STRING_NAME,     /* maximum length of an object name */
diff --git a/cpukit/posix/src/shm.c b/cpukit/posix/src/shm.c
index 131aa1384b..5030a9376e 100644
--- a/cpukit/posix/src/shm.c
+++ b/cpukit/posix/src/shm.c
@@ -35,7 +35,6 @@ static void _POSIX_Shm_Manager_initialization( void )
     _Configuration_POSIX_Maximum_shms,
     sizeof( POSIX_Shm_Control ),
diff --git a/cpukit/rtems/src/barrier.c b/cpukit/rtems/src/barrier.c
index a2912389e9..59b0a5d142 100644
--- a/cpukit/rtems/src/barrier.c
+++ b/cpukit/rtems/src/barrier.c
@@ -39,8 +39,7 @@ static void _Barrier_Manager_initialization(void)
     Configuration_RTEMS_API.maximum_barriers,
     sizeof( Barrier_Control ),     /* size of this object's control block */
-    false,                         /* true if the name is a string */
-    RTEMS_MAXIMUM_NAME_LENGTH,     /* maximum length of an object name */
diff --git a/cpukit/rtems/src/dpmem.c b/cpukit/rtems/src/dpmem.c
index 2522a59951..ccecdfd6cc 100644
--- a/cpukit/rtems/src/dpmem.c
+++ b/cpukit/rtems/src/dpmem.c
@@ -37,8 +37,7 @@ static void _Dual_ported_memory_Manager_initialization(void)
     sizeof( Dual_ported_memory_Control ),
-    false,                        /* true if names of this object are strings */
-    RTEMS_MAXIMUM_NAME_LENGTH,    /* maximum length of each object's name */
diff --git a/cpukit/rtems/src/msg.c b/cpukit/rtems/src/msg.c
index 44a0727ea4..8060735beb 100644
--- a/cpukit/rtems/src/msg.c
+++ b/cpukit/rtems/src/msg.c
@@ -39,8 +39,7 @@ static void _Message_queue_Manager_initialization(void)
     sizeof( Message_queue_Control ),
     _Message_queue_MP_Send_extract_proxy
diff --git a/cpukit/rtems/src/part.c b/cpukit/rtems/src/part.c
index 4df676ed7a..d395f34342 100644
--- a/cpukit/rtems/src/part.c
+++ b/cpukit/rtems/src/part.c
@@ -36,8 +36,7 @@ static void _Partition_Manager_initialization(void)
     Configuration_RTEMS_API.maximum_partitions,
     sizeof( Partition_Control ), /* size of this object's control block */
     _Partition_MP_Send_extract_proxy  /* Proxy extraction support callout */
diff --git a/cpukit/rtems/src/ratemon.c b/cpukit/rtems/src/ratemon.c
index dd3ca29cdd..a8681dda44 100644
--- a/cpukit/rtems/src/ratemon.c
+++ b/cpukit/rtems/src/ratemon.c
@@ -36,8 +36,7 @@ static void _Rate_monotonic_Manager_initialization(void)
     Configuration_RTEMS_API.maximum_periods,
     sizeof( Rate_monotonic_Control ),/* size of this object's control block */
diff --git a/cpukit/rtems/src/region.c b/cpukit/rtems/src/region.c
index 892c680f15..4fbce63160 100644
--- a/cpukit/rtems/src/region.c
+++ b/cpukit/rtems/src/region.c
@@ -47,8 +47,7 @@ static void _Region_Manager_initialization(void)
     Configuration_RTEMS_API.maximum_regions,
     sizeof( Region_Control ),  /* size of this object's control block */
diff --git a/cpukit/rtems/src/rtemstimer.c b/cpukit/rtems/src/rtemstimer.c
index d60e4a9b48..f0a8c672fa 100644
--- a/cpukit/rtems/src/rtemstimer.c
+++ b/cpukit/rtems/src/rtemstimer.c
@@ -38,8 +38,7 @@ static void _Timer_Manager_initialization(void)
     Configuration_RTEMS_API.maximum_timers ,
     sizeof( Timer_Control ),   /* size of this object's control block */
diff --git a/cpukit/rtems/src/sem.c b/cpukit/rtems/src/sem.c
index 74ce661725..e91e2d14bf 100644
--- a/cpukit/rtems/src/sem.c
+++ b/cpukit/rtems/src/sem.c
@@ -33,8 +33,7 @@ static void _Semaphore_Manager_initialization(void)
      Configuration_RTEMS_API.maximum_semaphores,
     sizeof( Semaphore_Control ), /* size of this object's control block */
     _Semaphore_MP_Send_extract_proxy /* Proxy extraction support callout */
diff --git a/cpukit/sapi/src/extension.c b/cpukit/sapi/src/extension.c
index 9c496832ab..70246048a4 100644
--- a/cpukit/sapi/src/extension.c
+++ b/cpukit/sapi/src/extension.c
@@ -35,8 +35,7 @@ static void _Extension_Manager_initialization(void)
     OBJECTS_RTEMS_EXTENSIONS,
     rtems_configuration_get_maximum_extensions(),
     sizeof( Extension_Control ),
diff --git a/cpukit/score/src/objectgetnameasstring.c b/cpukit/score/src/objectgetnameasstring.c
index ed6a73c0f8..845334075a 100644
--- a/cpukit/score/src/objectgetnameasstring.c
+++ b/cpukit/score/src/objectgetnameasstring.c
@@ -114,7 +114,7 @@ char *_Objects_Get_name_as_string(
   _Objects_Name_to_string(
     the_object->name,
-    information->is_string,
+    _Objects_Has_string_name( information ),
     name,
     length
diff --git a/cpukit/score/src/objectidtoname.c b/cpukit/score/src/objectidtoname.c
index 85eb409a8e..63948160e6 100644
--- a/cpukit/score/src/objectidtoname.c
+++ b/cpukit/score/src/objectidtoname.c
@@ -40,7 +40,7 @@ Objects_Name_or_id_lookup_errors _Objects_Id_to_name (
   if ( !information )
     return OBJECTS_INVALID_ID;
-  if ( information->is_string )
+  if ( _Objects_Has_string_name( information ) )
   the_object = _Objects_Get(
diff --git a/cpukit/score/src/objectinitializeinformation.c b/cpukit/score/src/objectinitializeinformation.c
index 23c7819bfa..2105c325d3 100644
--- a/cpukit/score/src/objectinitializeinformation.c
+++ b/cpukit/score/src/objectinitializeinformation.c
@@ -30,8 +30,7 @@ void _Objects_Do_initialize_information(
   uint16_t             the_class,
   uint32_t             maximum,
   uint16_t             size,
-  bool                 is_string,
@@ -49,7 +48,6 @@ void _Objects_Do_initialize_information(
   information->inactive_per_block = 0;
   information->object_blocks      = 0;
   information->inactive           = 0;
-  information->is_string          = is_string;
    *  Set the maximum value to 0. It will be updated when objects are
diff --git a/cpukit/score/src/objectnamespaceremove.c b/cpukit/score/src/objectnamespaceremove.c
index cc2c954a77..122ed862b7 100644
--- a/cpukit/score/src/objectnamespaceremove.c
+++ b/cpukit/score/src/objectnamespaceremove.c
@@ -27,7 +27,7 @@ void _Objects_Namespace_remove_u32(
   Objects_Control           *the_object
   the_object->name.name_u32 = 0;
@@ -38,7 +38,7 @@ void _Objects_Namespace_remove_string(
   char *name;
   name = RTEMS_DECONST( char *, the_object->name.name_p );
   the_object->name.name_p = NULL;
   _Workspace_Free( name );
diff --git a/cpukit/score/src/objectnametoidstring.c b/cpukit/score/src/objectnametoidstring.c
index dd69f8a9ea..3bca0441e0 100644
--- a/cpukit/score/src/objectnametoidstring.c
+++ b/cpukit/score/src/objectnametoidstring.c
@@ -33,7 +33,7 @@ Objects_Control *_Objects_Get_by_name(
   size_t   max_name_length;
   uint32_t index;
   _Assert( _Objects_Allocator_is_owner() );
   if ( name == NULL ) {
diff --git a/cpukit/score/src/objectsetname.c b/cpukit/score/src/objectsetname.c
index 227de515ec..32197a3cf8 100644
--- a/cpukit/score/src/objectsetname.c
+++ b/cpukit/score/src/objectsetname.c
@@ -29,32 +29,33 @@ bool _Objects_Set_name(
   const char                *name
-  size_t                 length;
-  const char            *s;
+  if ( _Objects_Has_string_name( information ) ) {
+    size_t  length;
+    char   *dup;
-  s      = name;
-  length = strnlen( name, information->name_length );
+    length = strnlen( name, information->name_length );
+    dup = _Workspace_String_duplicate( name, length );
+    if ( dup == NULL ) {
+      return false;
-  if ( information->is_string ) {
-    char *d;
+    the_object->name.name_p = dup;
+  } else {
+    char c[ 4 ];
+    size_t i;
-    d = _Workspace_Allocate( length + 1 );
-    if ( !d )
-      return false;
+    memset( c, ' ', sizeof( c ) );
-    _Workspace_Free( (void *)the_object->name.name_p );
-    the_object->name.name_p = NULL;
+    for ( i = 0; i < 4; ++i ) {
+      if ( name[ i ] == '\0') {
+        break;
-    strncpy( d, name, length );
-    d[length] = '\0';
-    the_object->name.name_p = d;
-  } else {
-    the_object->name.name_u32 =  _Objects_Build_name(
-      ((length)     ? s[ 0 ] : ' '),
-      ((length > 1) ? s[ 1 ] : ' '),
-      ((length > 2) ? s[ 2 ] : ' '),
-      ((length > 3) ? s[ 3 ] : ' ')
+      c[ i ] = name[ i ];
+    the_object->name.name_u32 =
+      _Objects_Build_name( c[ 0 ], c[ 1 ], c[ 2 ], c[ 3 ] );
   return true;
diff --git a/cpukit/score/src/thread.c b/cpukit/score/src/thread.c
index b63a6b14cd..5c27ee00ef 100644
--- a/cpukit/score/src/thread.c
+++ b/cpukit/score/src/thread.c
@@ -58,8 +58,7 @@ void _Thread_Initialize_information(
     the_class,
     maximum,
     _Thread_Control_size,
-    false,
     NULL
diff --git a/testsuites/psxtests/psxobj01/init.c b/testsuites/psxtests/psxobj01/init.c
index ca1fbc52ee..52cad3462d 100644
--- a/testsuites/psxtests/psxobj01/init.c
+++ b/testsuites/psxtests/psxobj01/init.c
@@ -45,7 +45,6 @@ rtems_task Init(
     4,           /* the_class */
     0,           /* maximum */
     4,           /* size */
-    true,        /* is_string */
     10,          /* maximum_name_length */
     NULL         /* Objects_Thread_queue_Extract_callout extract */
2.16.4
