[PATCH 5/7] score: Optimize object lookup
Mon Nov 26 13:12:12 UTC 2018
Use the maximum ID for the ID to object translation.  Using the maximum
ID gets rid of an additional load from the object information in
_Objects_Get().  In addition, object lookups fail for every ID in case
the object information is cleared to zero.  This makes it a bit more
robust during system startup (see new tests in spconfig02).
The local table no longer needs a NULL pointer entry at array index
zero.  Adjust all the object iteration loops accordingly.
Remove Objects_Information::minimum_id since it contains only redundant
information.  Add _Objects_Get_minimum_id() to get the minimum ID.
Update #3621.
 cpukit/include/rtems/score/objectimpl.h        |  26 ++-
 cpukit/posix/src/killinfo.c                    |   2 +-
 cpukit/rtems/src/ratemonreportstatistics.c     |  10 +-
 cpukit/rtems/src/ratemonresetall.c             |  12 +-
 cpukit/rtems/src/rtemsobjectgetclassinfo.c     |   2 +-
 cpukit/score/src/objectallocate.c              |   9 +-
 cpukit/score/src/objectextendinformation.c     |  20 +--
 cpukit/score/src/objectfree.c                  |   3 +-
 cpukit/score/src/objectgetlocal.c              |  24 ++-
 cpukit/score/src/objectgetnext.c               |   2 +-
 cpukit/score/src/objectgetnoprotection.c       |  19 +-
 cpukit/score/src/objectinitializeinformation.c |  17 +-
 cpukit/score/src/objectnametoid.c              |   4 +-
 cpukit/score/src/objectnametoidstring.c        |   2 +-
 cpukit/score/src/objectshrinkinformation.c     |  10 +-
 cpukit/score/src/threaditerate.c               |   2 +-
 testsuites/sptests/spconfig02/init.c           | 238 ++++++++++++++++++++++---
 17 files changed, 303 insertions(+), 99 deletions(-)
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index c3597c33ff..a516e21c65 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -120,8 +120,6 @@ typedef void ( *Objects_Thread_queue_Extract_callout )(
  *  manage each class of objects.
 typedef struct {
-  /** This is the minimum valid id of this object class. */
-  Objects_Id        minimum_id;
   /** This is the maximum valid id of this object class. */
   Objects_Id        maximum_id;
   /** This points to the table of local objects. */
@@ -191,6 +189,11 @@ extern uint16_t _Objects_Maximum_nodes;
 #define _Objects_Maximum_nodes 1
 #endif
+ * This is the minimum object ID index associated with an object.
+#define OBJECTS_INDEX_MINIMUM 1U
  *  The following is the list of information blocks per API for each object
  *  class.  From the ID, we can go to one of these information blocks,
@@ -831,6 +834,22 @@ RTEMS_INLINE_ROUTINE bool _Objects_Are_ids_equal(
   return ( left == right );
+ * Returns the identifier with the minimum index for the specified identifier.
+ * The specified identifier must have valid API, class and node fields.
+ * @param[in] id The identifier to be processed.
+ * @return The corresponding ID with the minimum index.
+RTEMS_INLINE_ROUTINE Objects_Id _Objects_Get_minimum_id( Objects_Id id )
+  id &= ~OBJECTS_INDEX_MASK;
+  id += (Objects_Id) OBJECTS_INDEX_MINIMUM << OBJECTS_INDEX_START_BIT;
+  return id;
  * This function sets the pointer to the local_table object
  * referenced by the index.
@@ -856,9 +875,10 @@ RTEMS_INLINE_ROUTINE void _Objects_Set_local_object(
    *  where the Id is known to be good.  Therefore, this should NOT
    *  occur in normal situations.
+  _Assert( index >= OBJECTS_INDEX_MINIMUM );
   _Assert( index <= information->maximum );
-  information->local_table[ index ] = the_object;
+  information->local_table[ index - OBJECTS_INDEX_MINIMUM ] = the_object;
diff --git a/cpukit/posix/src/killinfo.c b/cpukit/posix/src/killinfo.c
index 6f45b29ec6..cabd91c700 100644
--- a/cpukit/posix/src/killinfo.c
+++ b/cpukit/posix/src/killinfo.c
@@ -210,7 +210,7 @@ int _POSIX_signals_Send(
     maximum = the_info->maximum;
     object_table = the_info->local_table;
-    for ( index = 1 ; index <= maximum ; index++ ) {
+    for ( index = 0 ; index < maximum ; ++index ) {
       the_thread = (Thread_Control *) object_table[ index ];
       if ( !the_thread )
diff --git a/cpukit/rtems/src/ratemonreportstatistics.c b/cpukit/rtems/src/ratemonreportstatistics.c
index 1f7542f8df..cf04a787e3 100644
--- a/cpukit/rtems/src/ratemonreportstatistics.c
+++ b/cpukit/rtems/src/ratemonreportstatistics.c
@@ -35,6 +35,7 @@ void rtems_rate_monotonic_report_statistics_with_plugin(
   rtems_status_code                      status;
+  rtems_id                               maximum_id;
   rtems_id                               id;
   rtems_rate_monotonic_period_statistics the_stats;
   rtems_rate_monotonic_period_status     the_status;
@@ -67,9 +68,12 @@ ididididid NNNN ccccc mmmmmm X
    * Cycle through all possible ids and try to report on each one.  If it
    * is a period that is inactive, we just get an error back.  No big deal.
-  for ( id=_Rate_monotonic_Information.minimum_id ;
-        id <= _Rate_monotonic_Information.maximum_id ;
-        id++ ) {
+  maximum_id = _Rate_monotonic_Information.maximum_id;
+  for (
+    id = _Objects_Get_minimum_id( maximum_id ) ;
+    id <= maximum_id ;
+    ++id
     status = rtems_rate_monotonic_get_statistics( id, &the_stats );
     if ( status != RTEMS_SUCCESSFUL )
       continue;
diff --git a/cpukit/rtems/src/ratemonresetall.c b/cpukit/rtems/src/ratemonresetall.c
index a8418e82c4..c9e9089528 100644
--- a/cpukit/rtems/src/ratemonresetall.c
+++ b/cpukit/rtems/src/ratemonresetall.c
@@ -25,7 +25,8 @@
 void rtems_rate_monotonic_reset_all_statistics( void )
-  Objects_Id        id;
+  rtems_id id;
     * Prevent allocation or deallocation of any of the periods while we are
@@ -37,9 +38,12 @@ void rtems_rate_monotonic_reset_all_statistics( void )
      * Cycle through all possible ids and try to reset each one.  If it
-          id++ ) {
+    for (
+      ++id
       (void) rtems_rate_monotonic_reset_statistics( id );
diff --git a/cpukit/rtems/src/rtemsobjectgetclassinfo.c b/cpukit/rtems/src/rtemsobjectgetclassinfo.c
index ffcbd96cae..3ebe3535f5 100644
--- a/cpukit/rtems/src/rtemsobjectgetclassinfo.c
+++ b/cpukit/rtems/src/rtemsobjectgetclassinfo.c
@@ -44,7 +44,7 @@ rtems_status_code rtems_object_get_class_information(
    * Return information about this object class to the user.
-  info->minimum_id  = obj_info->minimum_id;
+  info->minimum_id  = _Objects_Get_minimum_id( obj_info->maximum_id );
   info->maximum_id  = obj_info->maximum_id;
   info->auto_extend = obj_info->auto_extend;
   info->maximum     = obj_info->maximum;
diff --git a/cpukit/score/src/objectallocate.c b/cpukit/score/src/objectallocate.c
index 81e322757c..2f991477da 100644
--- a/cpukit/score/src/objectallocate.c
+++ b/cpukit/score/src/objectallocate.c
@@ -62,16 +62,15 @@ Objects_Control *_Objects_Allocate_unprotected(
      *  extend information base.
-    if ( !the_object ) {
+    if ( the_object == NULL ) {
       _Objects_Extend_information( information );
       the_object = _Objects_Get_inactive( information );
-    if ( the_object ) {
-      uint32_t   block;
+    if ( the_object != NULL ) {
+      Objects_Maximum block;
-      block = (uint32_t) _Objects_Get_index( the_object->id ) -
-              _Objects_Get_index( information->minimum_id );
+      block = _Objects_Get_index( the_object->id ) - OBJECTS_INDEX_MINIMUM;
       block /= information->objects_per_block;
       information->inactive_per_block[ block ]--;
diff --git a/cpukit/score/src/objectextendinformation.c b/cpukit/score/src/objectextendinformation.c
index b8e72f93b6..a8346ce937 100644
--- a/cpukit/score/src/objectextendinformation.c
+++ b/cpukit/score/src/objectextendinformation.c
@@ -48,7 +48,6 @@ void _Objects_Extend_information(
   uint32_t          block;
   uint32_t          index_base;
   uint32_t          index_end;
-  uint32_t          minimum_index;
   uint32_t          index;
   uint32_t          maximum;
   size_t            object_block_size;
@@ -65,11 +64,9 @@ void _Objects_Extend_information(
    *  extend the block table, then we will change do_extend.
   do_extend     = true;
-  minimum_index = _Objects_Get_index( information->minimum_id );
-  index_base    = minimum_index;
+  index_base    = 0;
   block         = 0;
-  /* if ( information->maximum < minimum_index ) */
   if ( information->object_blocks == NULL )
     block_count = 0;
   else {
@@ -149,7 +146,7 @@ void _Objects_Extend_information(
      *  Allocate the tables and break it up.
     object_blocks_size = block_count * sizeof( *object_blocks );
-    local_table_size = ( maximum + minimum_index ) * sizeof( *local_table );
+    local_table_size =  maximum * sizeof( *local_table );
     table_size = object_blocks_size
       + local_table_size
       + block_count * sizeof( *inactive_per_block );
@@ -181,7 +178,7 @@ void _Objects_Extend_information(
     block_count--;
-    if ( information->maximum > minimum_index ) {
+    if ( information->maximum > 0 ) {
        *  Copy each section of the table over. This has to be performed as
        *  separate parts as size of each block has changed.
@@ -199,15 +196,8 @@ void _Objects_Extend_information(
       memcpy(
         local_table,
         information->local_table,
-        ( information->maximum + minimum_index ) * sizeof( *local_table )
+        information->maximum * sizeof( *local_table )
-    } else {
-       *  Deal with the special case of the 0 to minimum_index
-      for ( index = 0; index < minimum_index; index++ ) {
-        local_table[ index ] = NULL;
@@ -256,7 +246,7 @@ void _Objects_Extend_information(
       information->the_api,
       information->the_class,
       _Objects_Local_node,
-      index
+      index + OBJECTS_INDEX_MINIMUM
     _Chain_Initialize_node( &the_object->Node );
diff --git a/cpukit/score/src/objectfree.c b/cpukit/score/src/objectfree.c
index 3e7c8e409c..cf31a5b24e 100644
--- a/cpukit/score/src/objectfree.c
+++ b/cpukit/score/src/objectfree.c
@@ -37,8 +37,7 @@ void _Objects_Free(
     Objects_Maximum inactive;
     objects_per_block = information->objects_per_block;
-    block = _Objects_Get_index( the_object->id );
-    block -= _Objects_Get_index( information->minimum_id );
     block /= objects_per_block;
     ++information->inactive_per_block[ block ];
diff --git a/cpukit/score/src/objectgetlocal.c b/cpukit/score/src/objectgetlocal.c
index a1a81db436..0706698b7d 100644
--- a/cpukit/score/src/objectgetlocal.c
+++ b/cpukit/score/src/objectgetlocal.c
@@ -31,23 +31,29 @@ Objects_Control *_Objects_Get(
   const Objects_Information *information
-  uint32_t index;
+  ISR_Level  level;
+  Objects_Id delta;
+  Objects_Id maximum_id;
+  Objects_Id end;
-  index = id - information->minimum_id + 1;
+  _ISR_Local_disable( level );
-  if ( information->maximum >= index ) {
-    Objects_Control *the_object;
+  maximum_id = information->maximum_id;
+  delta = maximum_id - id;
+  end = _Objects_Get_index( maximum_id );
-    _ISR_lock_ISR_disable( lock_context );
+  if ( RTEMS_PREDICT_TRUE( delta < end ) ) {
+    Objects_Control *the_object;
-    the_object = information->local_table[ index ];
-    if ( the_object != NULL ) {
+    the_object =
+      information->local_table[ end - OBJECTS_INDEX_MINIMUM - delta ];
+    if ( RTEMS_PREDICT_TRUE( the_object != NULL ) ) {
       /* ISR disabled on behalf of caller */
+      _ISR_lock_Context_set_level( lock_context, level );
       return the_object;
-    _ISR_lock_ISR_enable( lock_context );
+  _ISR_Local_enable( level );
   return NULL;
diff --git a/cpukit/score/src/objectgetnext.c b/cpukit/score/src/objectgetnext.c
index a46c02f2c2..054ed22fc1 100644
--- a/cpukit/score/src/objectgetnext.c
+++ b/cpukit/score/src/objectgetnext.c
@@ -36,7 +36,7 @@ Objects_Control *_Objects_Get_next(
       return NULL;
     if (_Objects_Get_index(id) == OBJECTS_ID_INITIAL_INDEX)
-        next_id = information->minimum_id;
+        next_id = _Objects_Get_minimum_id( information->maximum_id );
     else
         next_id = id;
diff --git a/cpukit/score/src/objectgetnoprotection.c b/cpukit/score/src/objectgetnoprotection.c
index 85692234fa..e5045b26de 100644
--- a/cpukit/score/src/objectgetnoprotection.c
+++ b/cpukit/score/src/objectgetnoprotection.c
@@ -25,19 +25,16 @@ Objects_Control *_Objects_Get_no_protection(
-  uint32_t         index;
+  Objects_Id delta;
+  Objects_Id end;
-   * You can't just extract the index portion or you can get tricked
-   * by a value between 1 and maximum.
-    if ( (the_object = information->local_table[ index ]) != NULL ) {
-      return the_object;
+    return information->local_table[ end - OBJECTS_INDEX_MINIMUM - delta ];
diff --git a/cpukit/score/src/objectinitializeinformation.c b/cpukit/score/src/objectinitializeinformation.c
index a341dc1a5d..530e4e10ba 100644
--- a/cpukit/score/src/objectinitializeinformation.c
+++ b/cpukit/score/src/objectinitializeinformation.c
@@ -37,9 +37,7 @@ void _Objects_Do_initialize_information(
 #endif
-  static Objects_Control *null_local_table = NULL;
-  Objects_Maximum         maximum_per_allocation;
+  Objects_Maximum maximum_per_allocation;
   information->the_api            = the_api;
   information->the_class          = the_class;
@@ -48,6 +46,7 @@ void _Objects_Do_initialize_information(
   information->inactive_per_block = 0;
   information->object_blocks      = 0;
   information->inactive           = 0;
+  information->local_table        = NULL;
    *  Set the maximum value to 0. It will be updated when objects are
@@ -78,18 +77,6 @@ void _Objects_Do_initialize_information(
   information->objects_per_block = maximum_per_allocation;
-   *  Provide a null local table entry for the case of any empty table.
-  information->local_table = &null_local_table;
-   *  Calculate minimum and maximum Id's
-  minimum_index = (maximum_per_allocation == 0) ? 0 : 1;
-  information->minimum_id =
-    _Objects_Build_id( the_api, the_class, _Objects_Local_node, minimum_index );
    *  Calculate the maximum name length
diff --git a/cpukit/score/src/objectnametoid.c b/cpukit/score/src/objectnametoid.c
index 030d64a4bd..c3b014e3e1 100644
--- a/cpukit/score/src/objectnametoid.c
+++ b/cpukit/score/src/objectnametoid.c
@@ -29,7 +29,7 @@ Objects_Name_or_id_lookup_errors _Objects_Name_to_id_u32(
   bool                       search_local_node;
-  uint32_t                   index;
+  Objects_Maximum            index;
 #if defined(RTEMS_MULTIPROCESSING)
   Objects_Name               name_for_mp;
 #endif
@@ -52,7 +52,7 @@ Objects_Name_or_id_lookup_errors _Objects_Name_to_id_u32(
    search_local_node = true;
   if ( search_local_node ) {
-    for ( index = 1; index <= information->maximum; index++ ) {
+    for ( index = 0; index < information->maximum; ++index ) {
       if ( !the_object )
         continue;
diff --git a/cpukit/score/src/objectnametoidstring.c b/cpukit/score/src/objectnametoidstring.c
index 3bca0441e0..a015d5fc25 100644
--- a/cpukit/score/src/objectnametoidstring.c
+++ b/cpukit/score/src/objectnametoidstring.c
@@ -52,7 +52,7 @@ Objects_Control *_Objects_Get_by_name(
     *name_length_p = name_length;
diff --git a/cpukit/score/src/objectshrinkinformation.c b/cpukit/score/src/objectshrinkinformation.c
index cf3618f8fa..3b1841a16b 100644
--- a/cpukit/score/src/objectshrinkinformation.c
+++ b/cpukit/score/src/objectshrinkinformation.c
@@ -28,9 +28,9 @@ void _Objects_Shrink_information(
   Objects_Maximum objects_per_block;
-  Objects_Maximum index_base;
   Objects_Maximum block_count;
+  Objects_Maximum index_base;
   _Assert( _Objects_Allocator_is_owner() );
@@ -39,14 +39,14 @@ void _Objects_Shrink_information(
-  index_base = _Objects_Get_index( information->minimum_id );
-  block_count = ( information->maximum - index_base ) / objects_per_block;
+  block_count = information->maximum / objects_per_block;
+  index_base = 0;
   for ( block = 0; block < block_count; block++ ) {
     if ( information->inactive_per_block[ block ] == objects_per_block ) {
       Chain_Node       *node;
       const Chain_Node *tail;
-      uint32_t          index_end;
+      Objects_Maximum   index_end;
       node = _Chain_First( &information->Inactive );
       tail = _Chain_Immutable_tail( &information->Inactive );
@@ -57,7 +57,7 @@ void _Objects_Shrink_information(
         uint32_t         index;
         object = (Objects_Control *) node;
-        index = _Objects_Get_index( object->id );
+        index = _Objects_Get_index( object->id ) - OBJECTS_INDEX_MINIMUM;
          *  Get the next node before the node is extracted
diff --git a/cpukit/score/src/threaditerate.c b/cpukit/score/src/threaditerate.c
index eff3472d57..9fa9b89166 100644
--- a/cpukit/score/src/threaditerate.c
+++ b/cpukit/score/src/threaditerate.c
@@ -39,7 +39,7 @@ void _Thread_Iterate(
       continue;
-    for ( i = 1 ; i <= information->maximum ; ++i ) {
+    for ( i = 0 ; i < information->maximum ; ++i ) {
       Thread_Control *the_thread;
       the_thread = (Thread_Control *) information->local_table[ i ];
diff --git a/testsuites/sptests/spconfig02/init.c b/testsuites/sptests/spconfig02/init.c
index 34631fece2..ee889293bc 100644
--- a/testsuites/sptests/spconfig02/init.c
+++ b/testsuites/sptests/spconfig02/init.c
@@ -18,6 +18,7 @@
+#include <rtems/sysinit.h>
 #include <tmacros.h>
@@ -25,7 +26,7 @@ const char rtems_test_name[] = "SPCONFIG 2";
 static const rtems_name name = rtems_build_name('N', 'A', 'M', 'E');
-static void test_barrier(void)
+static void test_barrier_create(void)
   rtems_status_code sc;
   rtems_id id;
@@ -34,7 +35,33 @@ static void test_barrier(void)
   rtems_test_assert(sc == RTEMS_TOO_MANY);
-static void test_message_queue(void)
+static void test_barrier_delete(void)
+  rtems_status_code sc;
+  rtems_id id;
+  sc = rtems_barrier_delete(0);
+  rtems_test_assert(sc == RTEMS_INVALID_ID);
+  id = rtems_build_id(OBJECTS_CLASSIC_API, OBJECTS_RTEMS_BARRIERS, 1, 0);
+  sc = rtems_barrier_delete(id);
+static void test_barrier_get(void)
+  rtems_id id;
+  sc = rtems_barrier_wait(0, RTEMS_NO_TIMEOUT);
+  sc = rtems_barrier_wait(id, RTEMS_NO_TIMEOUT);
+static void test_message_queue_create(void)
   rtems_id id;
@@ -47,6 +74,12 @@ static void test_message_queue(void)
     &id
+static void test_message_queue_delete(void)
+  rtems_id id;
   sc = rtems_message_queue_delete(0);
@@ -56,7 +89,21 @@ static void test_message_queue(void)
-static void test_partition(void)
+static void test_message_queue_get(void)
+  rtems_id id;
+  uint32_t count;
+  sc = rtems_message_queue_flush(0, &count);
+  id = rtems_build_id(OBJECTS_CLASSIC_API, OBJECTS_RTEMS_MESSAGE_QUEUES, 1, 0);
+  sc = rtems_message_queue_flush(id, &count);
+static void test_partition_create(void)
   rtems_id id;
@@ -71,6 +118,12 @@ static void test_partition(void)
     &id
+static void test_partition_delete(void)
+  rtems_id id;
   sc = rtems_partition_delete(0);
@@ -80,13 +133,32 @@ static void test_partition(void)
-static void test_rate_monotonic(void)
+static void test_partition_get(void)
+  rtems_id id;
+  sc = rtems_partition_return_buffer(0, NULL);
+  id = rtems_build_id(OBJECTS_CLASSIC_API, OBJECTS_RTEMS_PARTITIONS, 1, 0);
+  sc = rtems_partition_return_buffer(id, NULL);
+static void test_rate_monotonic_create(void)
   rtems_id id;
   sc = rtems_rate_monotonic_create(name, &id);
+static void test_rate_monotonic_delete(void)
+  rtems_id id;
   sc = rtems_rate_monotonic_delete(0);
@@ -96,7 +168,20 @@ static void test_rate_monotonic(void)
-static void test_region(void)
+static void test_rate_monotonic_get(void)
+  rtems_id id;
+  sc = rtems_rate_monotonic_cancel(0);
+  id = rtems_build_id(OBJECTS_CLASSIC_API, OBJECTS_RTEMS_PERIODS, 1, 0);
+  sc = rtems_rate_monotonic_cancel(id);
+static void test_region_create(void)
   rtems_id id;
@@ -111,6 +196,12 @@ static void test_region(void)
     &id
+static void test_region_delete(void)
+  rtems_id id;
   sc = rtems_region_delete(0);
@@ -120,7 +211,20 @@ static void test_region(void)
-static void test_semaphore(void)
+static void test_region_get(void)
+  rtems_id id;
+  sc = rtems_region_return_segment(0, NULL);
+  id = rtems_build_id(OBJECTS_CLASSIC_API, OBJECTS_RTEMS_REGIONS, 1, 0);
+  sc = rtems_region_return_segment(id, NULL);
+static void test_semaphore_create(void)
   rtems_id id;
@@ -133,6 +237,12 @@ static void test_semaphore(void)
     &id
+static void test_semaphore_delete(void)
+  rtems_id id;
   sc = rtems_semaphore_delete(0);
@@ -142,7 +252,20 @@ static void test_semaphore(void)
-static void test_task(void)
+static void test_semaphore_get(void)
+  rtems_id id;
+  sc = rtems_semaphore_release(0);
+  id = rtems_build_id(OBJECTS_CLASSIC_API, OBJECTS_RTEMS_SEMAPHORES, 1, 0);
+  sc = rtems_semaphore_release(id);
+static void test_task_create(void)
   rtems_id id;
@@ -156,19 +279,41 @@ static void test_task(void)
     &id
+static void test_task_delete(void)
+  rtems_id id;
   id = rtems_build_id(OBJECTS_CLASSIC_API, OBJECTS_RTEMS_TASKS, 1, 0);
   sc = rtems_task_delete(id);
-static void test_timer(void)
+static void test_task_get(void)
+  rtems_id id;
+  id = rtems_build_id(OBJECTS_CLASSIC_API, OBJECTS_RTEMS_TASKS, 1, 0);
+  sc = rtems_task_resume(id);
+static void test_timer_create(void)
   rtems_id id;
   sc = rtems_timer_create(name, &id);
+static void test_timer_delete(void)
+  rtems_id id;
   sc = rtems_timer_delete(0);
@@ -178,7 +323,20 @@ static void test_timer(void)
-static void test_user_extensions(void)
+static void test_timer_get(void)
+  rtems_id id;
+  sc = rtems_timer_reset(0);
+  id = rtems_build_id(OBJECTS_CLASSIC_API, OBJECTS_RTEMS_TIMERS, 1, 0);
+  sc = rtems_timer_reset(id);
+static void test_user_extensions_create(void)
   rtems_id id;
@@ -187,6 +345,12 @@ static void test_user_extensions(void)
   memset(&table, 0, sizeof(table));
   sc = rtems_extension_create(name, &table, &id);
+static void test_user_extensions_delete(void)
+  rtems_id id;
   sc = rtems_extension_delete(0);
@@ -246,22 +410,56 @@ static void test_some_id_to_name(void)
 static void Init(rtems_task_argument arg)
-  rtems_print_printer_printk(&rtems_test_printer);
-  TEST_BEGIN();
-  test_barrier();
-  test_message_queue();
-  test_partition();
-  test_rate_monotonic();
-  test_region();
-  test_semaphore();
-  test_task();
-  test_timer();
-  test_user_extensions();
+  test_barrier_create();
+  test_barrier_delete();
+  test_barrier_get();
+  test_message_queue_create();
+  test_message_queue_delete();
+  test_message_queue_get();
+  test_partition_create();
+  test_partition_delete();
+  test_partition_get();
+  test_rate_monotonic_create();
+  test_rate_monotonic_delete();
+  test_rate_monotonic_get();
+  test_region_create();
+  test_region_delete();
+  test_region_get();
+  test_semaphore_create();
+  test_semaphore_delete();
+  test_semaphore_get();
+  test_task_create();
+  test_task_delete();
+  test_task_get();
+  test_timer_create();
+  test_timer_delete();
+  test_timer_get();
+  test_user_extensions_create();
+  test_user_extensions_delete();
   test_some_id_to_name();
   TEST_END();
   rtems_test_exit(0);
+static void before_object_information_initialization(void)
+  rtems_print_printer_printk(&rtems_test_printer);
+  TEST_BEGIN();
+  test_task_get();
+  test_timer_get();
+RTEMS_SYSINIT_ITEM(
+  before_object_information_initialization,
+  RTEMS_SYSINIT_INITIAL_EXTENSIONS,
+  RTEMS_SYSINIT_ORDER_LAST
 #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
 #define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
2.16.4
