[PATCH v2] rtemstoolkit: Add unit testing for the python modules
Tue Nov 27 04:58:24 UTC 2018
On 27/11/2018 04:28, Vijay Kumar Banerjee wrote:
> On Mon, 26 Nov 2018 at 16:27, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     > On 26 Nov 2018, at 6:57 pm, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>     <mailto:vijaykumar9597 at gmail.com>> wrote:
>     >> On Mon, Nov 26, 2018 at 06:28:33PM +1100, Chris Johns wrote:
>     >>> On 26 Nov 2018, at 5:21 pm, Vijay Kumar Banerjee
>     <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>     >>> I'm getting the result Invalid while running hello.exe with rtems-test
>     on leon3 (without coverage option)
>     >>> attaching the log.
>     >> Can you please revert or not apply patch 1 and let me know what happens?
>     I have a feeling the coverage Qemu may be the old or different settings.
>     > it works after reverting the first patch.
>     Can you define ‘qemu_use_serial_console’ when coverage is enabled? Doing
>     this will work with the coverage qemu.
> ..... how to do that ?
I would:
1. Define 'coverage' in tester/rt/coverage.py in 'macros_'. See macrocs.py for
the call https://git.rtems.org/rtems-tools/tree/rtemstoolkit/macros.py#n442.
2. In https://git.rtems.org/rtems-tools/tree/tester/rtems/testing/qemu.cfg#n61
move this logic up to line 51 and use something like:
 # Coverage, some builds of qemu support coverage.
 %ifdef coverage
  %define qemu_use_serial_console
  %ifn %{defined bsp_qemu_cov_opts}
   %define bsp_qemu_cov_opts %{nil}
  %endif
 %endif
