m68k/mcf5235 : permission denied to a specific test , Why?
Shashvat Jain shashvatjain2002 at gmail.com
Wed Nov 28 07:28:58 UTC 2018
Hello,
After I enabled the per section support on the mcf5235 bsp ,
on the initial "make install" it said that permission is denied for
loopback-init.o file
, while other tests before it were built successfully ,
so i had to give "chmod +x loopback-init.o" , which solved the problem .
The question is why did the permission denied came on loopback test only ?
diff has been attached here .
please tell if you see the same problem ,
which file should i refer so that the permission is given without needing
to make any further changes  .
diff --git a/bsps/m68k/mcf5235/config/mcf5235.cfg
b/bsps/m68k/mcf5235/config/mcf5235.cfg
index aed4e2ed5c..cf838b11e5 100644
--- a/bsps/m68k/mcf5235/config/mcf5235.cfg
+++ b/bsps/m68k/mcf5235/config/mcf5235.cfg
@@ -7,7 +7,7 @@ RTEMS_CPU=m68k
 include $(RTEMS_ROOT)/make/custom/default.cfg
 #  This contains the compiler options necessary to select the CPU model
-#  and (hopefully) optimize for it.
+#  and (hopefully) optimize for it.
 CPU_CFLAGS = -mcpu=5235
 # optimize flag: typically -O2
@@ -15,8 +15,8 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
 # FIXME: Disabled because linkcmds lacks proper KEEP() directives. See
#2571.
 # The following two lines enable compiling and linking on per element.
-# CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
-# LDFLAGS = -Wl,--gc-sections
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+LDFLAGS = -Wl,--gc-sections
 ifndef MTARGET
 MTARGET=ram
Regards
--Shashvat
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181128/7488ea16/attachment.html>
