[PATCH v2] rtemstoolkit: Add unit testing for the python modules
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Nov 30 14:59:07 UTC 2018
On Tue, 27 Nov 2018 at 13:30, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On Tue, 27 Nov 2018 at 10:28, Chris Johns <chrisj at rtems.org> wrote:
>> On 27/11/2018 04:28, Vijay Kumar Banerjee wrote:
>> > On Mon, 26 Nov 2018 at 16:27, Chris Johns <chrisj at rtems.org
>> > <mailto:chrisj at rtems.org>> wrote:
>> > > On 26 Nov 2018, at 6:57 pm, Vijay Kumar Banerjee <
>> > <mailto:vijaykumar9597 at gmail.com>> wrote:
>> > >> On Mon, Nov 26, 2018 at 06:28:33PM +1100, Chris Johns wrote:
>> > >>> On 26 Nov 2018, at 5:21 pm, Vijay Kumar Banerjee
>> > <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>> > >>> I'm getting the result Invalid while running hello.exe with
>> rtems-test
>> > on leon3 (without coverage option)
>> > >>> attaching the log.
>> > >> Can you please revert or not apply patch 1 and let me know what
>> happens?
>> > I have a feeling the coverage Qemu may be the old or different
>> settings.
>> > > it works after reverting the first patch.
>> > Can you define ‘qemu_use_serial_console’ when coverage is enabled?
>> Doing
>> > this will work with the coverage qemu.
>> > ..... how to do that ?
>> I would:
>> 1. Define 'coverage' in tester/rt/coverage.py in 'macros_'. See
>> macrocs.py for
>> the call
>> https://git.rtems.org/rtems-tools/tree/rtemstoolkit/macros.py#n442.
>> 2. In
>> https://git.rtems.org/rtems-tools/tree/tester/rtems/testing/qemu.cfg#n61
>> move this logic up to line 51 and use something like:
>> # Coverage, some builds of qemu support coverage.
>> %ifdef coverage
>> %define qemu_use_serial_console
>> %ifn %{defined bsp_qemu_cov_opts}
>> %define bsp_qemu_cov_opts %{nil}
>> %endif
>> %endif
>> Thank you for explaining in such detail. It's working after this change.
> I have attached the patch in this email.
ping :)
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181130/746c4619/attachment.html>
