[PATCH 16/21] rtems: Avoid <rtems/score/timecounter.h> in API
    Sebastian Huber
    Thu Nov  8 12:52:09 UTC 2018
Use a real function for rtems_clock_get_uptime_seconds().
Update #3598.
 cpukit/Makefile.am                       |  1 +
 cpukit/include/rtems/imfs.h              |  1 +
 cpukit/include/rtems/rtems/clock.h       |  8 +-------
 cpukit/include/rtems/rtems/types.h       |  1 +
 cpukit/rtems/src/clockgetuptimeseconds.c | 31 +++++++++++++++++++++++++++++++
 5 files changed, 35 insertions(+), 7 deletions(-)
 create mode 100644 cpukit/rtems/src/clockgetuptimeseconds.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 9a52db7661..0c9e05d234 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -673,6 +673,7 @@ librtemscpu_a_SOURCES += rtems/src/clockgettod.c
 librtemscpu_a_SOURCES += rtems/src/clockgettodtimeval.c
 librtemscpu_a_SOURCES += rtems/src/clockgetuptime.c
 librtemscpu_a_SOURCES += rtems/src/clockgetuptimenanoseconds.c
+librtemscpu_a_SOURCES += rtems/src/clockgetuptimeseconds.c
 librtemscpu_a_SOURCES += rtems/src/clockgetuptimetimeval.c
 librtemscpu_a_SOURCES += rtems/src/clockset.c
 librtemscpu_a_SOURCES += rtems/src/clocktick.c
diff --git a/cpukit/include/rtems/imfs.h b/cpukit/include/rtems/imfs.h
index 3d2048afeb..e83209508c 100644
--- a/cpukit/include/rtems/imfs.h
+++ b/cpukit/include/rtems/imfs.h
@@ -21,6 +21,7 @@
 #include <rtems/libio_.h>
 #include <rtems/pipe.h>
+#include <rtems/score/timecounter.h>
  * @brief In-Memory File System Support.
diff --git a/cpukit/include/rtems/rtems/clock.h b/cpukit/include/rtems/rtems/clock.h
index da833eac48..f3f406d2e6 100644
--- a/cpukit/include/rtems/rtems/clock.h
+++ b/cpukit/include/rtems/rtems/clock.h
@@ -33,9 +33,6 @@
 #include <rtems/config.h>
-#include <rtems/score/timecounterimpl.h>
-#include <sys/time.h> /* struct timeval */
  *  @defgroup ClassicClock Clocks
@@ -265,10 +262,7 @@ void rtems_clock_get_uptime_timeval( struct timeval *uptime );
  * @retval The system uptime in seconds.
-RTEMS_INLINE_ROUTINE time_t rtems_clock_get_uptime_seconds( void )
-  return _Timecounter_Time_uptime - 1;
+time_t rtems_clock_get_uptime_seconds( void );
  * @brief Returns the system uptime in nanoseconds.
diff --git a/cpukit/include/rtems/rtems/types.h b/cpukit/include/rtems/rtems/types.h
index 2028c427f0..13adf175a6 100644
--- a/cpukit/include/rtems/rtems/types.h
+++ b/cpukit/include/rtems/rtems/types.h
@@ -23,6 +23,7 @@
 #include <sys/_timespec.h>
+#include <sys/_timeval.h>
 #include <stdint.h>
 #include <rtems/score/heap.h>
diff --git a/cpukit/rtems/src/clockgetuptimeseconds.c b/cpukit/rtems/src/clockgetuptimeseconds.c
new file mode 100644
index 0000000000..ad412b2234
--- /dev/null
+++ b/cpukit/rtems/src/clockgetuptimeseconds.c
@@ -0,0 +1,31 @@
+ * @file
+ * @ingroup ClassicClock
+ * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+ * http://www.rtems.com/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/rtems/clock.h>
+  return _Timecounter_Time_uptime - 1;
2.16.4
