Status of m32c port?
Thu Nov 8 16:22:58 UTC 2018
On Thu, Nov 8, 2018, 9:57 AM Sebastian Huber <
sebastian.huber at embedded-brains.de wrote:
> On 08/11/2018 16:16, Sebastian Huber wrote:
> > On 08/11/2018 16:06, Joel Sherrill wrote:
> >> On Thu, Nov 8, 2018 at 8:59 AM Sebastian Huber
> >> <sebastian.huber at embedded-brains.de
> >> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >>     Hello,
> >>     I try to get rid of the proc_ptr type currently. What is the
> >>     status of
> >>     the m32c port? Are interrupts supported at all?
> >> Interrupts are not supported.
> >>     If not, then I suggest to remove this port right now. The tools are
> >>     already quite out dated.tools
> >> DJ Delorie was/is the tools port maintainer and he recently stepped
> >> down.
> >> I don't see the  tool situation getting better.
> >> I thought I filed a ticket heading the m32c down this path. But maybe I
> >> just sent an email to the list about it.
> > Yes, there was a discussion in January 2018:
> > https://lists.rtems.org/pipermail/users/2018-January/031991.html
> > No response from the user side. I was also under the impression that
> > this was a fully functional port. I will remove this architecture next
> > week if nobody objects.
> > https://devel.rtems.org/ticket/3599
> Should we remove the RTEMS support for m32c also from upstream GCC,
> Binutils, Newlib and GDB?
Might as well. It isn't that much code that is soecific to RTEMS vs the
port itself.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181108/b16617d9/attachment-0002.html>
