[PATCH] tester: Support testing all riscv bsps on Spike
Thu Nov 8 23:05:29 UTC 2018
On Thu, Nov 8, 2018 at 5:01 PM Chris Johns <chrisj at rtems.org> wrote:
> On 09/11/2018 07:43, Hesham Almatary wrote:
> >  tester/rtems/testing/bsps/rv32i_spike.ini     | 38 +++++++++++++++++++
> >  tester/rtems/testing/bsps/rv32iac_spike.ini   | 38 +++++++++++++++++++
> >  tester/rtems/testing/bsps/rv32im_spike.ini    | 38 +++++++++++++++++++
> >  tester/rtems/testing/bsps/rv32imac_spike.ini  | 38 +++++++++++++++++++
> >  tester/rtems/testing/bsps/rv32imafc_spike.ini | 38 +++++++++++++++++++
> >  tester/rtems/testing/bsps/rv32imafd_spike.ini | 38 +++++++++++++++++++
> >  .../rtems/testing/bsps/rv32imafdc_spike.ini   | 38 +++++++++++++++++++
> >  .../testing/bsps/rv64imac_medany_spike.ini    | 38 +++++++++++++++++++
> >  tester/rtems/testing/bsps/rv64imac_spike.ini  | 38 +++++++++++++++++++
> >  .../testing/bsps/rv64imafd_medany_spike.ini   | 38 +++++++++++++++++++
> >  tester/rtems/testing/bsps/rv64imafd_spike.ini | 38 +++++++++++++++++++
> >  .../testing/bsps/rv64imafdc_medany_spike.ini  | 38 +++++++++++++++++++
> >  .../rtems/testing/bsps/rv64imafdc_spike.ini   | 38 +++++++++++++++++++
> >  13 files changed, 494 insertions(+)
> >  create mode 100644 tester/rtems/testing/bsps/rv32i_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv32iac_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv32im_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv32imac_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv32imafc_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv32imafd_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv32imafdc_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv64imac_medany_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv64imac_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv64imafd_medany_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv64imafd_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv64imafdc_medany_spike.ini
> >  create mode 100644 tester/rtems/testing/bsps/rv64imafdc_spike.ini
> Looks good. OK to push.
Please push.
Thank you.
Out of curiosity, will qemu run all the variants also?
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181108/ebd9538f/attachment-0002.html>
