arm/altera-cyclone-v doxygen patch
Gedare Bloom
gedare at rtems.org
Fri Nov 9 17:44:22 UTC 2018
On Fri, Nov 9, 2018 at 9:03 AM, Sebastian Huber <
> On 08/11/2018 21:18, Gedare Bloom wrote:
>> On Thu, Nov 8, 2018 at 1:42 AM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de <mailto:sebastian.huber at embedd
>> ed-brains.de>> wrote:
>> On 08/11/2018 04:52, Gedare Bloom wrote:
>> Attached is a patch from GCI 2018 adding doxygen to the
>> altera-cyclone-v.
>> 6545323948244992_1541638792_0001-arm-altera-cyclone-v-Update
>> -Doxygen-GCI-2018.patch
>> From f69a935ea34fb617cab4632830e60184fe380d30 Mon Sep 17
>> 00:00:00 2001
>> From: shashvatjain<shashvatjain2002 at gmail.com
>> <mailto:shashvatjain2002 at gmail.com>>
>> Date: Thu, 8 Nov 2018 06:17:49 +0530
>> Subject: [PATCH] arm/altera cyclone v: Update Doxygen (GCI 2018)
>> bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h | 9 ++++++++
>> bsps/arm/altera-cyclone-v/include/bsp.h | 18
>> bsps/arm/altera-cyclone-v/include/bsp/hwlib.h | 16
>> .../arm/altera-cyclone-v/include/bsp/i2cdrv.h | 17
>> bsps/arm/altera-cyclone-v/include/bsp/irq.h | 22
>> 5 files changed, 81 insertions(+), 1 deletion(-)
>> diff --git a/bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h
>> b/bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h
>> index 650974751e..529d19980f 100644
>> --- a/bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h
>> +++ b/bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h
>> @@ -1,3 +1,12 @@
>> + * @file
>> + * @ingroup altera-cyclone-v_i2c
>> I think CamelCase is used in most places for Doxygen internal names.
>> It appears we have not been doing this in the BSPs doxygen so far. A
>> decision should be made whether to start doing it this way (and fix the
>> ones that are there), or to use the underscores like the other BSP doxygen
>> does.
> CamelCase is used throughout the cpukit. The good thing with CamelCase for
> the Doxygen stuff is that there are no conflicts with C scope identifiers
> since we don't use CamelCase in source code.
I chatted this over with Joel. We think it will be best to merge a few more
GCI efforts that add the bsp using this underscore notation (we have about
5 pending), and then we'll generate GCI tasks to convert the BSP doxygen to
use CamelCase before we add more doxygen to remaining BSPs.
I can confirm that two @ingroup works.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181109/362c0de7/attachment-0002.html>
