Adding Benchmark test for the test case " mq_receive: not available: block"(GCI 2018)
Mon Nov 12 04:45:09 UTC 2018
On Sun, Nov 11, 2018, 9:33 PM Shashvat Jain <shashvatjain2002 at gmail.com
wrote:
> hello ,
> multiple test cases have been defined in a single test
> https://git.rtems.org/rtems/tree/testsuites/psxtmtests/psxtmmq01/psxtmmq01.doc
> The task instructs me to add  a new test , just for clarification , will
> it be right to add  the test case "mq_receive: not available: block" in
> the same test?
I don't think so. It would need to follow the same multiple task blocking
pattern used by something a mutex or semaphore unavailable and block.
Answering from my phone but task blocking and unblocking tests tend to have
multiple threads and be standalone tests
 But if this case is missing, you found a legitimate one to add.
--joel
> thank you
> --Shashvat
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181111/fa5fe911/attachment-0002.html>
