rtems-docs : Build failure
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon Nov 12 06:26:49 UTC 2018
On Mon, 12 Nov 2018 at 11:26, Chris Johns <chrisj at rtems.org> wrote:
> On 12/11/2018 16:50, Vijay Kumar Banerjee wrote:
> > I'm getting a waf failure, trying to build the documentation with Fedora
> 28.
> > pdfTex version --> pdfTeX 3.14159265-2.6-1.40.19 (TeX Live 2018)
> > I'm pasting the error below.
> I cannot tell which manual the build is failing. Can you see which manual?
> User manual.
> > Build failed
> > Traceback (most recent call last):
> > File
> "/home/lunatic/development/rtems/docs/rtems-docs/.waf-1.9.7-d27222240ebc8bcbca7fcd8f4ae914fb/waflib/Task.py",
> > line 145, in process
> > ret=self.run()
> > File
> "/home/lunatic/development/rtems/docs/rtems-docs/.waf-1.9.7-d27222240ebc8bcbca7fcd8f4ae914fb/waflib/Tools/tex.py",
> > line 216, in run
> > self.call_latex()
> > File
> > line 231, in call_latex
> > self.check_status('error when calling latex',self.texfun())
> > File
> > line 116, in check_status
> > raise Errors.WafError('%r command exit status %r'%(msg,retcode))
> > WafError: 'error when calling latex' command exit status 1
> Is latex installed? Try:
> $ type latex
> latex is hashed (/usr/local/texlive/2018/bin/x86_64-linux/latex)
> If this is OK there will be a latex log file in the manual's build
> directory,
> for example for the User manual it is build/user/latex/user.log and the
> actual
> error should be in it.
> I only see "Undefined control sequence" errors. (attaching the log)
I have the pdf generated though, but the waf gives this error.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181112/2b76e098/attachment-0002.html>
