[POSIX Benchmark Test] psxtmmqrcvblock01 made (GCI 2018)
Thu Nov 15 20:11:45 UTC 2018
I am moving this on to devel to speed the process up but I see one thing
and something I need to think about.
(1) init.c has DOS (Windows CR/LF) and needs to be UNIX style.
I ran dos2unix on it.
(2) The time seems high.  Running on psim (PowerPC simulator) which
reports times in instructions, I see this:
joel at rtbf64c b-psim]$ grep e_receive log/*
log/tm09:rtems_message_queue_receive: available - 150
log/tm10:rtems_message_queue_receive: not available NO_WAIT - 88
log/tm10:rtems_message_queue_receive: not available caller blocks - 801
log/tmoverhd:overhead: rtems_message_queue_receive - 5
[joel at rtbf64c b-psim]$ grep q_receive log/*
log/psxtmmq01:mq_receive: available - 164
log/psxtmmqrcvblock01:mq_receive: not available: block - 1156
Notice that tm10's blocking case is 801 instructions vs 1156. So there are
355 more instructions on the posix case. Looking at that more closely, I
think I believe it is accurate that posix mq's are more expensive than
Classic API message queues.
I will post the patch with a couple of clean ups for further review.
--joel
On Thu, Nov 15, 2018 at 1:54 PM Shashvat Jain <shashvatjain2002 at gmail.com>
wrote:
> ---------- Forwarded message ---------
> From: Shashvat Jain <shashvatjain2002 at gmail.com>
> Date: Fri, Nov 16, 2018 at 12:32 AM
> Subject: [POSIX Benchmark Test] psxtmmqrcvblock01 made (GCI 2018)
> To: <devel at rtems.org>
> hello ,
> here is the patch which includes the  psxtmmqrcvblock01 test for test case
> "mq_receive : not available : block"
> please verify the output and the code.
> Thank you
> --Shashvat
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181115/18a4d505/attachment-0002.html>
