rtems-test error with coverage
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Nov 23 13:50:58 UTC 2018
On Fri, 23 Nov 2018 at 16:21, Chris Johns <chrisj at rtems.org> wrote:
> On 23 Nov 2018, at 8:55 pm, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
> On Fri, 23 Nov 2018 at 15:09, Chris Johns <chrisj at rtems.org> wrote:
>> On 23/11/18 7:32 pm, Vijay Kumar Banerjee wrote:
>> > Hi,
>> > I was trying to run coverage with rtems-test on a fresh install, and
>> faced
>> > the following errors. This is strange as everything was working and I
>> can't
>> > figure out what went wrong.
>> > Also, I don't see covoar executable in the covoar/ directory.
>> > I'm using Python 2.7.15
>> Are you sure? The latest version selects the python used.
>> `python --version` returns 2.7.15
> The python command may not be used. It could python3.
> If you do ...
>>  $ export RTEMS_PYTHON_OVERRIDE=python2
> ... does it work?
>> Yes, this worked. Now I see
> error: coverage: covoar not found
> I am not sure about this error but it does mean there maybe some issues
> with python3.
> For some reason, the covoar executable is not installed in the
tester/covoar directory, where
the the script is searching for it.
The covoar is installed in the bin directory. Is there any reason that
script searches for covoar
in the tester/ instead of the bin directory?
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181123/0b8a58a6/attachment-0002.html>
