psxtmtests: add psxtmmqrcvblock02 (GCI 2018)
Joel Sherrill
joel at rtems.org
Sat Nov 24 22:49:21 UTC 2018
This test is not following the right pattern. Please look at the mq_receive
test
case. It is based on a different template and measures 100 threads blocking
while performing this operation.
This test needs to be reworked to follow the other pattern.
Please fix and resubmit.
Thanks.
--joel
On Sat, Nov 24, 2018 at 3:53 PM Himanshu Sekhar Nayak <
himanshuwindows8.1 at gmail.com> wrote:
> Hi guys,
> Here is the updated patch with minimal changes.
> Thanks
> Himanshu
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181124/7e681f28/attachment-0002.html>
