[m68k/gen68360]Add per-section compilation and linking support
Shashvat Jain shashvatjain2002 at gmail.com
Sun Nov 25 07:57:50 UTC 2018
I managed to do " git --amend " here is the updated patch with message
"Closes #2566"
thank you
Regards
--Shashvat
On Sun, Nov 25, 2018 at 1:23 PM Shashvat Jain <shashvatjain2002 at gmail.com>
wrote:
> Hello ,
> I just enabled the per-function and per-data element section support for
> the gen68340 bsp in m68k architecture .
> The patch for the change has been attached
> anyone who pushes it , please add the message "Closes #2566"
> I forgot to add it , also please tell me how to edit the  message on a
> commit which is in source tree .
> Thank you :)
> Regards
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181125/312e7906/attachment-0002.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181125/312e7906/attachment-0002.obj>
