BSP for Microchip ATSAMA5D27-SOM1-EK1
dufault at hda.com dufault at hda.com
Sun Nov 25 18:42:15 UTC 2018
Thank you for the advice.  I will not need USB, but will need SDRAM and don’t need poor support.  Microchip? You tried to push RTEMS for this platform tied to space applications, are you monitoring this?  The platform looks like just what I need but not if you’re not supporting it.
> On Nov 25, 2018, at 13:23 , Thomas Dörfler <thomas.doerfler at embedded-brains.de> wrote:
> Peter,
> just to make you aware: we designed a board with the ATSAMV7 chip and hit some nasty and at least one really ugly bug: operating the USB interface concurrently with external SDRAM does not work. Half a year after reporting this bug, Microchip confirmed it, but did not plan any fix for it. BTW: The conbination (USB+SDRAM) was also available on Microchip's evaluation board, but obviously was not tested together at Microchips labs...
> So: I recommend you to tripple check, whether the ATSAMA5 meets all of your expectations.
> Kind regards,
> Thomas.
> ----- Ursprüngliche Mail -----
> Von: "Peter Dufault" <dufault at hda.com>
> An: "Development" <devel at rtems.org>
> Gesendet: Sonntag, 25. November 2018 18:38:19
> Betreff: BSP for Microchip ATSAMA5D27-SOM1-EK1
> I need to evaluate this for a multi-chip application.
> This part is a result of Microchip’s take-over of ATMEL.  I’m double-checking that to create a BSP based on this I should start with the existing ATSAMV7 BSP, I think the peripherals (e.g. network chip and so on) are the same as the existing ATSAMV7 port.
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> This email is delivered through the public internet using protocols subject to interception and tampering.
> devel mailing list
> devel at rtems.org
> embedded brains GmbH
> Thomas Doerfler
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: Thomas.Doerfler at embedded-brains.de
> Phone: +49-89-18 94 741-12
> Fax:   +49-89-18 94 741-09
> PGP: Public key available on request.
Peter
Peter Dufault
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181125/5f5cb475/attachment-0002.html>
