[PATCH v2] rtemstoolkit: Add unit testing for the python modules
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon Nov 26 06:21:24 UTC 2018
I'm getting the result Invalid while running hello.exe with rtems-test on
leon3 (without coverage option)
attaching the log.
On Mon, 26 Nov 2018 at 06:40, <chrisj at rtems.org> wrote:
> Hi,
> Please test these patches and report.
> The patches:
> - Add unittests for the rtemstoolkit python modules. To run enter:
> ./waf test
> The tests will be run for python2 and python3 is present on your
> host.
> - Improvie the reader thread line processor of child process stdio
> data. Switch the output streams to buffered io. This seems to
> fix some output related issues when running multiple simulators
> at once.
> - I have run the rtems-test command with a zynq qemu and erc32 using
> python2 and python3.
> - Fix GDB simulators on python3. The MI parsing was broken plus
> some stdin handling did not work on Python3.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181126/a69cd97e/attachment-0002.html>
Type: text/x-log
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181126/a69cd97e/attachment-0002.bin>
