[PATCH 4/7] score: Rename Objects_Information::allocation_size
    Sebastian Huber
    Mon Nov 26 13:12:11 UTC 2018
Rename Objects_Information::allocation_size in
Objects_Information::objects_per_block.  Adjust integer types in
_Objects_Shrink_information() and _Objects_Free().
Update #3621.
 cpukit/include/rtems/score/objectimpl.h        |  4 +--
 cpukit/score/src/objectallocate.c              |  2 +-
 cpukit/score/src/objectextendinformation.c     | 15 +++++------
 cpukit/score/src/objectfree.c                  | 24 ++++++++++--------
 cpukit/score/src/objectinitializeinformation.c |  2 +-
 cpukit/score/src/objectshrinkinformation.c     | 35 +++++++++++++++-----------
 6 files changed, 47 insertions(+), 35 deletions(-)
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index 3a64573f6b..c3597c33ff 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -131,7 +131,7 @@ typedef struct {
   /** This is the number of objects on the Inactive list. */
   Objects_Maximum   inactive;
   /** This is the number of objects in a block. */
-  Objects_Maximum   allocation_size;
+  Objects_Maximum   objects_per_block;
   /** This is the size in bytes of each object instance. */
   uint16_t          object_size;
@@ -750,7 +750,7 @@ RTEMS_INLINE_ROUTINE Objects_Maximum _Objects_Extend_size(
   const Objects_Information *information
-  return information->auto_extend ? information->allocation_size : 0;
+  return information->auto_extend ? information->objects_per_block : 0;
diff --git a/cpukit/score/src/objectallocate.c b/cpukit/score/src/objectallocate.c
index 97ced4bdf5..81e322757c 100644
--- a/cpukit/score/src/objectallocate.c
+++ b/cpukit/score/src/objectallocate.c
@@ -72,7 +72,7 @@ Objects_Control *_Objects_Allocate_unprotected(
       block = (uint32_t) _Objects_Get_index( the_object->id ) -
               _Objects_Get_index( information->minimum_id );
-      block /= information->allocation_size;
+      block /= information->objects_per_block;
       information->inactive_per_block[ block ]--;
       information->inactive--;
diff --git a/cpukit/score/src/objectextendinformation.c b/cpukit/score/src/objectextendinformation.c
index 3fc9cdd464..b8e72f93b6 100644
--- a/cpukit/score/src/objectextendinformation.c
+++ b/cpukit/score/src/objectextendinformation.c
@@ -73,19 +73,19 @@ void _Objects_Extend_information(
   if ( information->object_blocks == NULL )
     block_count = 0;
   else {
-    block_count = information->maximum / information->allocation_size;
+    block_count = information->maximum / information->objects_per_block;
     for ( ; block < block_count; block++ ) {
       if ( information->object_blocks[ block ] == NULL ) {
         do_extend = false;
         break;
       } else
-        index_base += information->allocation_size;
+        index_base += information->objects_per_block;
-  index_end = index_base + information->allocation_size;
+  index_end = index_base + information->objects_per_block;
-  maximum = (uint32_t) information->maximum + information->allocation_size;
+  maximum = (uint32_t) information->maximum + information->objects_per_block;
    *  We need to limit the number of objects to the maximum number
@@ -100,7 +100,8 @@ void _Objects_Extend_information(
    * Allocate the name table, and the objects and if it fails either return or
    * generate a fatal error depending on auto-extending being active.
-  object_block_size = information->allocation_size * information->object_size;
+  object_block_size = information->objects_per_block
+    * information->object_size;
   if ( information->auto_extend ) {
     new_object_block = _Workspace_Allocate( object_block_size );
     if ( !new_object_block )
@@ -243,8 +244,8 @@ void _Objects_Extend_information(
    *  Assign the new object block to the object block table.
   information->object_blocks[ block ] = new_object_block;
-  information->inactive_per_block[ block ] = information->allocation_size;
-  information->inactive += information->allocation_size;
+  information->inactive_per_block[ block ] = information->objects_per_block;
+  information->inactive += information->objects_per_block;
    *  Append to inactive chain.
diff --git a/cpukit/score/src/objectfree.c b/cpukit/score/src/objectfree.c
index 30ea1e36e5..3e7c8e409c 100644
--- a/cpukit/score/src/objectfree.c
+++ b/cpukit/score/src/objectfree.c
@@ -27,28 +27,32 @@ void _Objects_Free(
   Objects_Control     *the_object
-  uint32_t    allocation_size = information->allocation_size;
   _Assert( _Objects_Allocator_is_owner() );
   _Chain_Append_unprotected( &information->Inactive, &the_object->Node );
-    uint32_t    block;
+    Objects_Maximum block;
+    Objects_Maximum inactive;
+    objects_per_block = information->objects_per_block;
+    block = _Objects_Get_index( the_object->id );
+    block -= _Objects_Get_index( information->minimum_id );
+    block /= objects_per_block;
-    block = (uint32_t) (_Objects_Get_index( the_object->id ) -
-                        _Objects_Get_index( information->minimum_id ));
+    ++information->inactive_per_block[ block ];
-    information->inactive_per_block[ block ]++;
-    information->inactive++;
+    inactive = information->inactive;
+    ++inactive;
+    information->inactive = inactive;
      *  Check if the threshold level has been met of
-     *  1.5 x allocation_size are free.
+     *  1.5 x objects_per_block are free.
-    if ( information->inactive > ( allocation_size + ( allocation_size >> 1 ) ) ) {
+    if ( inactive > ( objects_per_block + ( objects_per_block >> 1 ) ) ) {
       _Objects_Shrink_information( information );
diff --git a/cpukit/score/src/objectinitializeinformation.c b/cpukit/score/src/objectinitializeinformation.c
index 90f50d544c..a341dc1a5d 100644
--- a/cpukit/score/src/objectinitializeinformation.c
+++ b/cpukit/score/src/objectinitializeinformation.c
@@ -76,7 +76,7 @@ void _Objects_Do_initialize_information(
    *  The allocation unit is the maximum value
-  information->allocation_size = maximum_per_allocation;
+  information->objects_per_block = maximum_per_allocation;
    *  Provide a null local table entry for the case of any empty table.
diff --git a/cpukit/score/src/objectshrinkinformation.c b/cpukit/score/src/objectshrinkinformation.c
index db085e1042..cf3618f8fa 100644
--- a/cpukit/score/src/objectshrinkinformation.c
+++ b/cpukit/score/src/objectshrinkinformation.c
@@ -27,9 +27,10 @@ void _Objects_Shrink_information(
-  uint32_t          block_count;
-  uint32_t          block;
-  uint32_t          index_base;
+  Objects_Maximum index_base;
+  Objects_Maximum block_count;
@@ -37,20 +38,26 @@ void _Objects_Shrink_information(
    * Search the list to find block or chunk with all objects inactive.
   index_base = _Objects_Get_index( information->minimum_id );
-  block_count = (information->maximum - index_base) /
-                 information->allocation_size;
+  block_count = ( information->maximum - index_base ) / objects_per_block;
   for ( block = 0; block < block_count; block++ ) {
-    if ( information->inactive_per_block[ block ] ==
-         information->allocation_size ) {
-      Chain_Node       *node = _Chain_First( &information->Inactive );
-      const Chain_Node *tail = _Chain_Immutable_tail( &information->Inactive );
-      uint32_t          index_end = index_base + information->allocation_size;
+    if ( information->inactive_per_block[ block ] == objects_per_block ) {
+      Chain_Node       *node;
+      const Chain_Node *tail;
+      uint32_t          index_end;
+      node = _Chain_First( &information->Inactive );
+      tail = _Chain_Immutable_tail( &information->Inactive );
+      index_end = index_base + objects_per_block;
       while ( node != tail ) {
-        Objects_Control *object = (Objects_Control *) node;
-        uint32_t         index = _Objects_Get_index( object->id );
+        Objects_Control *object;
+        uint32_t         index;
+        object = (Objects_Control *) node;
+        index = _Objects_Get_index( object->id );
          *  Get the next node before the node is extracted
@@ -70,11 +77,11 @@ void _Objects_Shrink_information(
       information->object_blocks[ block ] = NULL;
       information->inactive_per_block[ block ] = 0;
-      information->inactive -= information->allocation_size;
+      information->inactive -= objects_per_block;
       return;
+    index_base += objects_per_block;
2.16.4
