RSB set-builder Creates File Named "0"
Chris Johns
chrisj at rtems.org
Thu Nov 29 19:03:04 UTC 2018
> On 30 Nov 2018, at 4:27 am, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I have been seeing this for a couple of weeks. I decided to watch a build of the sparc
> tools and see when it happened. I set a script to test for the existence of 0 and kill the set-builder. In the rtems/ subdirectory of the RSB, the script killed the set-builder when the gdb build started. So I think something in the gdb bset file is creating this file.
It will be something related to the gdb python support I added:
https://git.rtems.org/rtems-source-builder/tree/source-builder/config/gdb-common-1.cfg#n70
Does it happen with the —dry-run option?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181130/8ded8616/attachment-0002.html>
