powerpc/ss555:Add per-section compilation and linking support(GCI 2018)
Fri Nov 30 15:24:56 UTC 2018
Hi
Thanks. I have tested this and am about to push it. My size drop was:
[joel at rtbf64c b-ss555-before]$ powerpc-rtems5-size `find . -name ticker.exe`
   text    data     bss     dec     hex filename
 119556    1380   15464  136400   214d0
./powerpc-rtems5/c/ss555/testsuites/samples/ticker.exe
[joel at rtbf64c b-ss555-before]$ cd ../b-ss555
[joel at rtbf64c b-ss555]$ powerpc-rtems5-size `find . -name ticker.exe`
  86384    1252   15092  102728   19148
Does that match yours?
--joel
On Fri, Nov 30, 2018 at 9:12 AM Shashvat Jain <shashvatjain2002 at gmail.com>
wrote:
> Hello ,
> The per-function section linking has been enabled under this patch.
> Thank you
> Regards
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20181130/1ef9bd0a/attachment-0002.html>
