[PATCH 11/25] Merge sapi/Makefile.am into cpukit/Makefile.am
Mon Oct 1 05:52:14 UTC 2018
On 25/09/2018 07:58, Chris Johns wrote:
> On 25/09/2018 15:30, Sebastian Huber wrote:
>> On 25/09/2018 00:27, Chris Johns wrote:
>>>>>> We would have to go from the symbol to the ELF file to the DWARF info of the
>>>>>> compilation unit.
>>>>> All info should be directly via the ELF and DWARF format. I do not know if we
>>>>> need to reference the ELF symbol table or we can just use the DWARF CU data.
>>>>> The
>>>>> use of objdump should be avoided.
>>>> I only briefly look into this, but you have to go from the rld::symbols::symbol
>>>> to the DWARF info somehow if DesiredSymbols.cc:95 is the right spot to add this
>>>> stuff.
>>> You could be right. The DWARF info will contain all symbols and more.
>>> Should these files move to the rtems.git repo?
>> The *.ini files or which files?
> Just the INI files, the files which describe the data.
>> I would leave the files where they are and fix
>> the issues first. Afterwards I would think about moving files around across
>> repositories.
> Oh of course, that is fine and it makes sense. I would like to understand the
> tasks and agree on them.
This stalled my background work on general RTEMS improvements (in this
case the build system). I think the path is clear. We use source tree
path regular expressions to assign source files to categories. The
source tree path is determined for each symbol by the DWARF compilation
unit information. The categories are defined in an INI file in
rtems-tools for now. Maybe later it is places somewhere else.
I would like to continue now with the build system changes. This will
break the coverage tool categories for some time.
Is there some documentation on how I can use the coverage tool? Which
BSP is recommended for test runs?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
