[PATCH] rtemstoolkit: Fix imports and fix all unittests.
chrisj at rtems.org
chrisj at rtems.org
Fri Oct 5 04:24:49 UTC 2018
rtemstoolkit/check.py | 36 ++++----
rtemstoolkit/config.py | 60 +++++++------
rtemstoolkit/configuration.py | 35 ++++++--
rtemstoolkit/darwin.py | 13 ++-
rtemstoolkit/execute.py | 16 ++--
rtemstoolkit/freebsd.py | 14 ++--
rtemstoolkit/git.py | 24 ++----
rtemstoolkit/host.py | 8 +-
rtemstoolkit/linux.py | 18 ++--
rtemstoolkit/log.py | 15 ++--
rtemstoolkit/macros.py | 52 +++++++-----
rtemstoolkit/mailer.py | 53 ++++++++----
rtemstoolkit/netbsd.py | 6 +-
rtemstoolkit/options.py | 140 +++++++++++++++----------------
rtemstoolkit/path.py | 16 ++--
rtemstoolkit/reraise.py | 6 +-
rtemstoolkit/rtems.py | 133 ++++++++++++++++++++++-------
rtemstoolkit/solaris.py | 6 +-
rtemstoolkit/stacktraces.py | 41 +++++++--
rtemstoolkit/textbox.py | 6 +-
rtemstoolkit/version.py | 26 +++---
tester/rt/check.py | 190 +++++++++++++++++++++++-------------------
tester/rt/run.py | 4 +-
tester/rt/test.py | 4 +-
24 files changed, 538 insertions(+), 384 deletions(-)
diff --git a/rtemstoolkit/check.py b/rtemstoolkit/check.py
index c6549bf..44cf6ba 100644
--- a/rtemstoolkit/check.py
+++ b/rtemstoolkit/check.py
@@ -28,6 +28,10 @@
# POSSIBILITY OF SUCH DAMAGE.
+# Unittest: python -m rtemstoolkit.check
# Check the defaults for a specific host.
@@ -36,24 +40,12 @@ from __future__ import print_function
import os
-# Support to handle use in a package and as a unit test.
-# If there is a better way to let us know.
-try:
- from . import error
- from . import execute
- from . import log
- from . import options
- from . import path
- from . import version
-except (ValueError, SystemError):
- import error
- import execute
- import log
- import options
- import path
- import version
+from rtemstoolkit import error
+from rtemstoolkit import execute
+from rtemstoolkit import log
+from rtemstoolkit import options
+from rtemstoolkit import path
+from rtemstoolkit import version
def _check_none(_opts, macro, value, constraint):
return True
@@ -97,12 +89,14 @@ def _check_exe(_opts, macro, value, constraint, silent = False):
if _check_paths(value, paths):
if absexe:
if not silent:
- log.notice('warning: exe: absolute exe found in path: (%s) %s' % (macro, orig_value))
+ log.notice('warning: exe: absolute exe found in path: (%s) %s' % \
+ (macro, orig_value))
return True
if constraint == 'optional':
if not silent:
- log.trace('warning: exe: optional exe not found: (%s) %s' % (macro, orig_value))
+ log.trace('warning: exe: optional exe not found: (%s) %s' % \
return True
if not silent:
@@ -168,7 +162,7 @@ def run():
try:
_opts = options.command_line(argv = sys.argv)
options.load(_opts)
- log.notice('RTEMS Source Builder - Check, v%s' % (version.string()))
+ log.notice('RTEMS Toolkit - Check, v%s' % (version.string()))
if host_setup(_opts):
print('Environment is ok')
else:
diff --git a/rtemstoolkit/config.py b/rtemstoolkit/config.py
index a16261b..0ec93de 100644
--- a/rtemstoolkit/config.py
+++ b/rtemstoolkit/config.py
@@ -1,6 +1,6 @@
# RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2010-2016 Chris Johns (chrisj at rtems.org)
+# Copyright 2010-2018 Chris Johns (chrisj at rtems.org)
# All rights reserved.
# This file is part of the RTEMS Tools package in 'rtems-tools'.
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.config
# This code is based on a tool I wrote to parse RPM spec files in the RTEMS
# project. This is now a configuration file format that has moved away from the
@@ -44,24 +48,12 @@ import os
import re
import sys
-try:
- from . import host
- from . import log
- import error
- import execute
- import host
- import log
- import options
- import path
+from rtemstoolkit import host
def _check_bool(value):
if value.isdigit():
@@ -756,13 +748,16 @@ class file(object):
break
configname = None
if configname is None:
- raise error.general('no config file found: %s' % (cfgname))
+ raise error.general('no config file found: %s' % \
+ (path.basename(cfgname)))
try:
- log.trace('config: %s: _open: %s' % (self.init_name, path.host(configname)))
+ log.trace('config: %s: _open: %s' % (self.init_name,
+ path.host(configname)))
config = open(path.host(configname), 'r')
except IOError as err:
- raise error.general('error opening config file: %s' % (path.host(configname)))
+ raise error.general('error opening config file: %s' % \
+ (path.host(configname)))
self.configpath += [configname]
self._includes += [configname]
@@ -845,21 +840,34 @@ def run():
import sys
try:
- # Run where defaults.mc is located
+ # Run from the top of RTEMS tools with:
+ # $ python -m rtemstoolkit.config \
+ # --file tester/rtems/testing/gdb.cfg \
+ # --config tester/rtems/testing:tester/config \
+ # --rtdir tester
long_opts = {
- # key macro handler param defs init
- '--file' : ('_file', 'path', True, None, False)
+ # key macro handler param defs init
+ '--file' : ('_file', 'path', True, None, False),
+ '--config' : ('_configdir', 'string', True, None, False),
+ '--rtdir' : ('_rtdir', 'path', True, None, False)
opts = options.command_line(base_path = '.',
argv = sys.argv,
long_opts = long_opts)
options.load(opts)
- s = file(opts.defaults['_file'], opts)
+ if opts.defaults.get_value('_configdir') is None:
+ raise error.general('no --config argument')
+ f = opts.defaults.get_value('_file')
+ if f is None:
+ raise error.general('no --file argument')
+ s = file(f, opts)
s.load(opts.defaults['_file'])
print(s)
del s
except error.general as gerr:
+ raise
print(gerr)
sys.exit(1)
except error.internal as ierr:
diff --git a/rtemstoolkit/configuration.py b/rtemstoolkit/configuration.py
index 10d97e5..04493f9 100644
--- a/rtemstoolkit/configuration.py
+++ b/rtemstoolkit/configuration.py
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.configuration
# Host specifics.
@@ -47,10 +51,12 @@ from rtemstoolkit import path
class configuration:
- def __init__(self):
+ def __init__(self, name = None):
self.config = configparser.ConfigParser()
self.ini = None
self.macro_filter = re.compile('\$\{.+\}')
+ if name is not None:
+ self.load(name)
def __str__(self):
if self.ini is None:
@@ -95,7 +101,7 @@ class configuration:
pass
return rec
- def get_items(self, section, err = True, flatten = True):
+ def get_items(self, section, err = True, flatten = True, dictionary = False):
try:
items = []
for name, key in self.config.items(section):
@@ -103,17 +109,24 @@ class configuration:
items += [(name, key.replace(os.linesep, ' '))]
else:
items += [(name, key)]
+ if dictionary:
+ items = dict(items)
return items
except:
if err:
raise error.general('config: section "%s" not found' % (section))
+ if dictionary:
+ return {}
return []
- def comma_list(self, section, label, err = True):
+ def comma_list(self, section, label, err = True, sort = True):
items = self.get_item(section, label, err)
if items is None:
return []
- return sorted(set([a.strip() for a in items.split(',')]))
+ items = set([a.strip() for a in items.split(',')])
+ if sort:
+ return sorted(items)
+ return items
def get_item_names(self, section, err = True):
try:
@@ -126,12 +139,13 @@ class configuration:
def has_section(self, section):
return self.config.has_section(section)
- def load(self, name):
+ def load(self, name, trace = False):
# Load all the files.
- self.ini = { 'base' : path.dirname(name),
- 'files' : [] }
+ if self.ini is None:
+ self.ini = { 'base' : path.dirname(name),
+ 'files' : [] }
includes = [name]
still_loading = True
while still_loading:
@@ -146,6 +160,8 @@ class configuration:
include = rebased_inc
if include not in self.ini['files']:
try:
+ if trace:
+ print('config: read: %s' % (include))
self.config.read(include)
except configparser.ParsingError as ce:
raise error.general('config: %s' % (ce))
@@ -155,6 +171,11 @@ class configuration:
if still_loading:
for section in self.config.sections():
includes += self.comma_list(section, 'include', err = False)
+ if trace and len(includes) > 0:
+ print('config: includes: %s' % (','.join(includes)))
def files(self):
return self.ini['files']
+if __name__ == "__main__":
+ print('No unittest, please add')
diff --git a/rtemstoolkit/darwin.py b/rtemstoolkit/darwin.py
index 0400174..57fca85 100644
--- a/rtemstoolkit/darwin.py
+++ b/rtemstoolkit/darwin.py
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.darwin
# This code is based on what ever doco about spec files I could find and
# RTEMS project's spec files.
@@ -35,14 +39,7 @@
import os
-try:
- import execute
def cpus():
sysctl = '/usr/sbin/sysctl '
diff --git a/rtemstoolkit/execute.py b/rtemstoolkit/execute.py
index 8e09b81..09532e5 100755
--- a/rtemstoolkit/execute.py
+++ b/rtemstoolkit/execute.py
@@ -28,6 +28,10 @@
# Execute commands or scripts.
@@ -46,16 +50,8 @@ import threading
import time
import traceback
-try:
- from . import log
- import error
- import log
# Trace exceptions
trace_threads = False
diff --git a/rtemstoolkit/freebsd.py b/rtemstoolkit/freebsd.py
index 2842394..609fef4 100644
--- a/rtemstoolkit/freebsd.py
+++ b/rtemstoolkit/freebsd.py
@@ -1,6 +1,6 @@
-# Copyright 2010-2017 Chris Johns (chrisj at rtems.org)
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.freebsd
@@ -39,12 +43,8 @@ import os
-try:
- from . import check
- import check
- import execute
+from rtemstoolkit import check
def cpus():
sysctl = '/sbin/sysctl '
diff --git a/rtemstoolkit/git.py b/rtemstoolkit/git.py
index 5f3af58..ba6e8c0 100644
--- a/rtemstoolkit/git.py
+++ b/rtemstoolkit/git.py
@@ -1,6 +1,6 @@
@@ -25,26 +25,20 @@
+# Unittest: python -m rtemstoolkit.git
# Provide some basic access to the git command.
import os
-try:
- from . import log
- import error
- import execute
- import log
- import path
class repo:
"""An object to manage a git repo."""
diff --git a/rtemstoolkit/host.py b/rtemstoolkit/host.py
index ea23b24..f284eef 100644
--- a/rtemstoolkit/host.py
+++ b/rtemstoolkit/host.py
@@ -1,6 +1,6 @@
-# Copyright 2017 Chris Johns (chrisj at rtems.org)
+# Copyright 2018 Chris Johns (chrisj at rtems.org)
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.host
# Host specifics.
@@ -113,9 +117,9 @@ def label(mode = 'all'):
if __name__ == '__main__':
import pprint
- pprint.pprint(platform())
_load()
print('Name : %s' % (name))
+ print('Label : %s' % (label()))
if is_windows:
status = 'Yes'
else:
diff --git a/rtemstoolkit/linux.py b/rtemstoolkit/linux.py
index 1d7f577..03a2226 100644
--- a/rtemstoolkit/linux.py
+++ b/rtemstoolkit/linux.py
@@ -1,6 +1,6 @@
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.linux
@@ -36,16 +40,8 @@
import os
import platform
-try:
- import execute
- import path
def cpus():
processors = '/bin/grep processor /proc/cpuinfo'
diff --git a/rtemstoolkit/log.py b/rtemstoolkit/log.py
index 3eb2c1b..2a3d1d8 100755
--- a/rtemstoolkit/log.py
+++ b/rtemstoolkit/log.py
@@ -1,6 +1,6 @@
# This file is part of the RTEMS Tools package in 'rtems-testing'.
@@ -28,6 +28,10 @@
# Log output to stdout and/or a file.
@@ -38,14 +42,7 @@ import os
import sys
import threading
-try:
- import error
# A global log.
diff --git a/rtemstoolkit/macros.py b/rtemstoolkit/macros.py
index ed8cd96..9422705 100644
--- a/rtemstoolkit/macros.py
+++ b/rtemstoolkit/macros.py
@@ -1,6 +1,6 @@
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.macros
# Macro tables.
@@ -40,24 +44,17 @@ import re
import os
import string
-try:
- from . import log
- import error
- import log
- import path
# Macro tables
class macros:
+ empty = {}
class macro_iterator:
def __init__(self, keys):
self.keys = keys
@@ -97,21 +94,22 @@ class macros:
self.read_maps = []
self.read_map_locked = False
self.write_map = 'global'
- self.rtpath = path.abspath(path.dirname(inspect.getfile(macros)))
- if path.dirname(self.rtpath).endswith('/share/rtems'):
- self.prefix = path.dirname(self.rtpath)[:-len('/share/rtems')]
- else:
- self.prefix = '.'
self.macros['global'] = {}
self.macros['global']['nil'] = ('none', 'none', '')
self.macros['global']['_cwd'] = ('dir',
'required',
path.abspath(os.getcwd()))
- self.macros['global']['_prefix'] = ('dir', 'required', self.prefix)
- self.macros['global']['_rtdir'] = ('dir',
- 'required',
- path.abspath(self.expand(rtdir)))
- self.macros['global']['_rttop'] = ('dir', 'required', self.prefix)
+ if rtdir is not None:
+ self.rtpath = path.abspath(path.dirname(inspect.getfile(macros)))
+ if path.dirname(self.rtpath).endswith('/share/rtems'):
+ self.prefix = path.dirname(self.rtpath)[:-len('/share/rtems')]
+ else:
+ self.prefix = '.'
+ self.macros['global']['_rttop'] = ('dir', 'required', self.prefix)
+ self.macros['global']['_prefix'] = ('dir', 'required', self.prefix)
+ self.macros['global']['_rtdir'] = ('dir',
+ 'required',
+ path.abspath(self.expand(rtdir)))
else:
self.macros = {}
for m in original.macros:
@@ -195,6 +193,8 @@ class macros:
if type(key) is not str:
raise TypeError('bad key type (want str): %s' % (type(key)))
if type(value) is not tuple:
+ if type(value) is not str or type(value) is not unicode:
+ value = str(value)
value = self._unicode_to_str(value)
if type(value) is str:
value = ('none', 'none', value)
@@ -463,6 +463,8 @@ class macros:
def expand(self, _str):
"""Simple basic expander of config file macros."""
+ if type(_str) is not str and type(_str) is not buffer:
+ raise TypeError('bad str type: %s' % (type(_str)))
start_str = _str
expanded = True
count = 0
@@ -523,6 +525,10 @@ class macros:
return True
def lock_read_map(self):
+ '''Lock the read map so it cannot be changed. This is useful if you wish to
+ override and force a map onto code that sets a new read mao,
self.read_map_locked = True
def unlock_read_map(self):
diff --git a/rtemstoolkit/mailer.py b/rtemstoolkit/mailer.py
index b5a0a1e..0ff7164 100644
--- a/rtemstoolkit/mailer.py
+++ b/rtemstoolkit/mailer.py
@@ -1,6 +1,6 @@
-# Copyright 2013-2016 Chris Johns (chrisj at rtems.org)
+# Copyright 2013-2018 Chris Johns (chrisj at rtems.org)
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.mailer
# Manage emailing results or reports.
@@ -38,18 +42,9 @@ import os
import smtplib
import socket
-try:
- import error
- import options
- import path
_options = {
'--mail' : 'Send email report or results.',
@@ -72,7 +67,7 @@ class mail:
self.opts = opts
def _args_are_macros(self):
- return type(self.opts) is 'command_line'
+ return isinstance(self.opts, options.command_line)
def _get_arg(self, arg):
if self._args_are_macros():
@@ -87,6 +82,14 @@ class mail:
value = None
return value
+ def to_address(self, default = None):
+ addr = self._get_arg('--mail-to')
+ if addr is None:
+ addr = default
+ if addr is None:
+ raise error.general('no valid to address for mail')
+ return addr
def from_address(self):
def _clean(l):
@@ -130,7 +133,7 @@ class mail:
def smtp_host(self):
host = self._get_arg('--smtp-host')
if host is not None:
- return host[1]
+ return host
host = self.opts.defaults.get_value('%{_mail_smtp_host}')
@@ -160,11 +163,27 @@ class mail:
self.send(to_addr, from_addr, body)
+ import copy
import sys
optargs = {}
+ args = sys.argv
+ for o in ['--mail',
+ '--smtp-host=localhost',
+ '--mail-to=you at sthere',
+ '--mail-from=me at here']:
+ if o.split('=')[0] not in args:
+ args += [o]
append_options(optargs)
- opts = options.load(sys.argv, optargs = optargs, defaults = 'defaults.mc')
+ opts = options.command_line(base_path = '.',
+ argv = args,
+ optargs = optargs,
+ defaults = 'rtemstoolkit/defaults.mc')
+ options.load(opts)
m = mail(opts)
+ print('To: %s' % (m.to_address()))
print('From: %s' % (m.from_address()))
print('SMTP Host: %s' % (m.smtp_host()))
- m.send(m.from_address(), 'Test mailer.py', 'This is a test')
+ try:
+ m.send(m.from_address(), 'Test mailer.py', 'This is a test')
+ except error.general as gerr:
+ print(gerr)
diff --git a/rtemstoolkit/netbsd.py b/rtemstoolkit/netbsd.py
index 112fba1..42af372 100644
--- a/rtemstoolkit/netbsd.py
+++ b/rtemstoolkit/netbsd.py
@@ -1,6 +1,6 @@
@@ -19,6 +19,10 @@
# along with RTEMS Tools. If not, see <http://www.gnu.org/licenses/>.
+# Unittest: python -m rtemstoolkit.netbsd
diff --git a/rtemstoolkit/options.py b/rtemstoolkit/options.py
index 77d9593..4425fe4 100644
--- a/rtemstoolkit/options.py
+++ b/rtemstoolkit/options.py
@@ -1,6 +1,6 @@
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.options
# Determine the defaults and load the specific file.
@@ -42,31 +46,70 @@ import os
import string
import sys
-try:
- from . import git
- from . import log
- from . import macros
- import error
- import execute
- import git
- import host
- import log
- import macros
- import path
- import version
+from rtemstoolkit import git
+from rtemstoolkit import macros
basepath = 'tb'
+def jobs(cpus, opt = None, macros = None):
+ try:
+ cpus = int(cpus)
+ except:
+ raise error.general('jobs: invalid host cpu value')
+ if opt is not None:
+ if opt == 'default':
+ if macros is None:
+ _jobs = cpus
+ else:
+ _jobs = macros.get_value('jobs')
+ if _jobs is not None:
+ if _jobs == 'none':
+ cpus = 0
+ elif _jobs == 'max':
+ pass
+ elif _jobs == 'half':
+ cpus = cpus / 2
+ else:
+ try:
+ cpus = int(_jobs)
+ except:
+ raise error.general('jobs: invalid %%{jobs} macro: %s' % (_jobs))
+ else:
+ opt = 'max'
+ if opt != 'default':
+ if opt == 'none':
+ cpus = 0
+ elif opt == 'max':
+ pass
+ elif opt == 'half':
+ cpus = cpus / 2
+ else:
+ ok = False
+ try:
+ i = int(opt)
+ cpus = i
+ ok = True
+ except:
+ pass
+ if not ok:
+ try:
+ f = float(opt)
+ cpus = f * cpus
+ ok = True
+ except:
+ pass
+ if not ok:
+ raise error.internal('bad jobs option: %s' % (opt))
+ if cpus <= 0:
+ cpu = 1
+ return cpus
class command_line(object):
"""Process the command line in a common way for all Tool Builder commands."""
@@ -90,6 +133,8 @@ class command_line(object):
if defaults is None:
defaults = macros.macros()
+ elif type(defaults) is str:
+ defaults = macros.macros(name = defaults)
self.long_opts = {
@@ -442,54 +487,7 @@ class command_line(object):
return um if len(um) else None
def jobs(self, cpus):
- try:
- cpus = int(cpus)
- except:
- raise error.general('invalid host cpu value')
- opt_jobs = self.opts['jobs']
- if opt_jobs == 'default':
- _jobs = self.defaults.get_value('jobs')
- if _jobs is not None:
- if _jobs == 'none':
- cpus = 0
- elif _jobs == 'max':
- pass
- elif _jobs == 'half':
- cpus = cpus / 2
- else:
- try:
- cpus = int(_jobs)
- except:
- raise error.general('invalid %%{jobs} value: %s' % (_jobs))
- else:
- opt_jobs = 'max'
- if opt_jobs != 'default':
- if opt_jobs == 'none':
- cpus = 0
- elif opt_jobs == 'max':
- pass
- elif opt_jobs == 'half':
- cpus = cpus / 2
- else:
- ok = False
- try:
- i = int(opt_jobs)
- cpus = i
- ok = True
- except:
- pass
- if not ok:
- try:
- f = float(opt_jobs)
- cpus = f * cpus
- ok = True
- except:
- pass
- if not ok:
- raise error.internal('bad jobs option: %s' % (opt_jobs))
- if cpus <= 0:
- cpu = 1
- return cpus
+ return jobs(cpus, opt = self.opts['jobs'], macros = self.defaults)
def params(self):
return self.opts['params']
diff --git a/rtemstoolkit/path.py b/rtemstoolkit/path.py
index 760f4bd..cc7f213 100644
--- a/rtemstoolkit/path.py
+++ b/rtemstoolkit/path.py
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.path
# Manage paths locally. The internally the path is in Unix or shell format and
# we convert to the native format when performing operations at the Python
@@ -41,16 +45,8 @@ import os
import shutil
import string
-try:
- from . import log
- import error
- import log
windows = os.name == 'nt'
diff --git a/rtemstoolkit/reraise.py b/rtemstoolkit/reraise.py
index 4b80861..f1b8891 100644
--- a/rtemstoolkit/reraise.py
+++ b/rtemstoolkit/reraise.py
@@ -1,6 +1,6 @@
-# Copyright 2013-2017 Chris Johns (chrisj at rtems.org)
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.reraise
import sys
diff --git a/rtemstoolkit/rtems.py b/rtemstoolkit/rtems.py
index 8aa22e5..cbd80b5 100755
--- a/rtemstoolkit/rtems.py
+++ b/rtemstoolkit/rtems.py
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.rtems
import copy
@@ -48,7 +52,7 @@ _prefix_path = '/opt/rtems'
def default_prefix():
- return path.join(_prefix_path, version.version())
+ return path.join(_prefix_path, str(version.version()))
def clean_windows_path():
'''On Windows MSYS2 prepends a path to itself to the environment path. This
@@ -62,23 +66,41 @@ def clean_windows_path():
if 'msys' in cspath[0] and cspath[0].endswith('bin'):
os.environ['PATH'] = os.pathsep.join(cspath[1:])
-def configuration_path():
- '''Return the path the configuration data path for RTEMS. The path is relative
- to the installed executable. Mangage the installed package and the in source
- tree when running from within the rtems-tools repo.
+def shared_path(name):
+ '''Return the path to a shared file folder for RTEMS. The path is relative to
+ the installed executable or we are testing and running from within the
+ rtems-tools repo.
+ exec_name = os.path.abspath(sys.argv[0])
+ for top in [path.dirname(exec_name),
+ path.dirname(path.dirname(exec_name))]:
+ shared = path.join(top, 'share', 'rtems', name)
+ if path.exists(shared):
+ break
+ shared = path.join(top, name)
+ break
+ shared = None
+ return shared
+def shared_file(name):
+ '''Return the path to a shared file for RTEMS. The path is relative to the
+ installed executable or we are testing and running from within the
+ rtems-tools repo.
- for top in [os.path.dirname(exec_name),
- os.path.dirname(os.path.dirname(exec_name))]:
- config_path = path.join(top, 'share', 'rtems', 'config')
- if path.exists(config_path):
+ name_path = path.join(top, 'share', 'rtems', name)
+ if path.exists(name_path):
break
- config_path = path.join(top, 'config')
+ name_path = path.join(top, name)
break
- config_path = None
- return config_path
+ name_path = None
+ return name_path
def configuration_file(config):
'''Return the path to a configuration file for RTEMS. The path is relative to
@@ -86,9 +108,9 @@ def configuration_file(config):
rtems-tools repo.
- return path.join(configuration_path(), config)
+ return shared_file(os.path.join('config', config))
-def bsp_configuration_file():
+def default_configuration_file():
'''Return the path to the BSP configuration file for RTEMS. The path is
relative to the installed executable or we are testing and running from
@@ -96,6 +118,14 @@ def bsp_configuration_file():
return configuration_file('rtems-bsps.ini')
+def arch_bsp(ab):
+ '''Split an arch/bsp string into it's arch and bsp parts.'''
+ if isinstance(ab, str):
+ abl = ab.split('/')
+ if len(abl) == 2:
+ return abl[0], abl[1]
+ return None, None
def __init__(self):
@@ -133,7 +163,7 @@ class configuration:
options += [opt]
return options
- def load(self, name, build):
+ def load(self, name, build = None):
self.config.load(name)
archs = []
self.profiles['profiles'] = \
@@ -243,7 +273,9 @@ class configuration:
return sorted(self.archs[arch]['bsps'])
def bsp_present(self, arch, bsp):
- return bsp in self.archs[arch]['bsps']
+ if arch in self.archs:
+ return bsp in self.archs[arch]['bsps']
+ return False
def bsp_excludes(self, arch, bsp):
excludes = self.archs[arch]['excludes'].keys()
@@ -275,20 +307,22 @@ class configuration:
raise error.general('invalid profile arch: %s' % (arch))
return ['%s/%s' % (arch, bsp) for bsp in self.profiles[profile]['bsps_%s' % (arch)]]
- def report(self, profiles = True, builds = True, architectures = True):
+ def report(self, profiles = True, builds = True, architectures = True, files = False):
width = 70
cols_1 = [width]
cols_2 = [10, width - 10]
- s = textbox.line(cols_1, line = '=', marker = '+', indent = 1)
- s1 = ' File(s)'
- for f in self.config.files():
- colon = ':'
- for l in textwrap.wrap(f, width = cols_2[1] - 3):
- s += textbox.row(cols_2, [s1, ' ' + l], marker = colon, indent = 1)
- colon = ' '
- s1 = ' ' * len(s1)
- s += textbox.line(cols_1, marker = '+', indent = 1)
- s += os.linesep
+ s = ''
+ if files:
+ s += textbox.line(cols_1, line = '=', marker = '+', indent = 1)
+ s1 = ' File(s)'
+ for f in self.config.files():
+ colon = ':'
+ for l in textwrap.wrap(f, width = cols_2[1] - 3):
+ s += textbox.row(cols_2, [s1, ' ' + l], marker = colon, indent = 1)
+ colon = ' '
+ s1 = ' ' * len(s1)
+ s += textbox.line(cols_1, marker = '+', indent = 1)
+ s += os.linesep
if profiles:
profiles = sorted(self.profiles['profiles'])
@@ -413,3 +447,46 @@ class configuration:
s += textbox.line(cols_b, marker = '+', indent = 1)
s += os.linesep
return s
+ def report_args(self, opts):
+ if 'rtems_config_report' in opts:
+ profiles = False
+ builds = False
+ archs = False
+ files = False
+ if opts.rtems_config_report == 'all':
+ profiles = True
+ builds = True
+ archs = True
+ files = True
+ elif opts.rtems_config_report == 'profiles':
+ profiles = True
+ elif opts.rtems_config_report == 'builds':
+ builds = True
+ elif opts.rtems_config_report == 'archs':
+ archs = True
+ elif opts.rtems_config_report == 'files':
+ files = True
+ return self.report(profiles, builds, archs, files)
+ return None
+def add_arguments(argsp, config_report_default = 'all'):
+ '''RTEMS Module arguments.'''
+ import argparse
+ argsp.add_argument('--rtems-config',
+ help = 'RTEMS configuration file (default: %(default)s).',
+ type = str,
+ default = default_configuration_file())
+ argsp.add_argument('--rtems-config-report',
+ help = 'Report the RTEMS configuration (default: %(const)s).',
+ type = str,
+ default = argparse.SUPPRESS,
+ const = config_report_default,
+ nargs = '?',
+ choices = ['all', 'profiles', 'builds', 'archs', 'files'])
+if __name__ == '__main__':
+ print('no unittest, please add')
diff --git a/rtemstoolkit/solaris.py b/rtemstoolkit/solaris.py
index dc3e490..9fcbab8 100644
--- a/rtemstoolkit/solaris.py
+++ b/rtemstoolkit/solaris.py
@@ -1,6 +1,6 @@
@@ -17,6 +17,10 @@
# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+# Unittest: python -m rtemstoolkit.solaris
diff --git a/rtemstoolkit/stacktraces.py b/rtemstoolkit/stacktraces.py
index e589618..9a16362 100644
--- a/rtemstoolkit/stacktraces.py
+++ b/rtemstoolkit/stacktraces.py
@@ -28,16 +28,43 @@
+# Unittest: python -m rtemstoolkit.stacktraces
import sys
+import threading
import traceback
-def trace():
+_lock = threading.Lock()
+def _thread_name(thread_id):
+ thread_name = ''
+ for t in threading.enumerate():
+ if t.ident == thread_id:
+ thread_name = t.name
+ return '%s (%s)' % (thread_name, thread_id)
+def stacks():
code = []
- for threadId, stack in sys._current_frames().items():
- code.append("\n# thread-id: %s" % threadId)
+ for thread_id, stack in sys._current_frames().items():
+ thread_label = _thread_name(thread_id)
+ code.append("] %s" % (thread_label))
for filename, lineno, name, line in traceback.extract_stack(stack):
- code.append('file: "%s", line %d, in %s' % (filename, lineno, name))
- if line:
- code.append(" %s" % (line.strip()))
- return '\n'.join(code)
+ code.append(' %-30s : %s:%d' % (name, filename, lineno))
+ if line:
+ code.append(' %s' % (line.strip()))
+ return code
+def trace(what, who, show_stacks = False):
+ _lock.acquire()
+ if show_stacks:
+ print('-' * 80)
+ if show_stacks:
+ for i in stacks():
+ print(' ' + i)
+ _lock.release()
+ trace('test', 'tester', show_stacks = True)
+ print(' -- END --')
diff --git a/rtemstoolkit/textbox.py b/rtemstoolkit/textbox.py
index 8341bdd..6936acb 100644
--- a/rtemstoolkit/textbox.py
+++ b/rtemstoolkit/textbox.py
@@ -1,6 +1,6 @@
+# Copyright 2017-2018 Chris Johns (chrisj at rtems.org)
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.textbox
diff --git a/rtemstoolkit/version.py b/rtemstoolkit/version.py
index d538d2a..d316804 100644
--- a/rtemstoolkit/version.py
+++ b/rtemstoolkit/version.py
@@ -28,6 +28,10 @@
+# Unittest: python -m rtemstoolkit.version
# Releasing RTEMS Tools
@@ -88,19 +92,9 @@ try:
except ImportError:
import ConfigParser as configparser
-# Support to handle importing when installed in a package and as a unit test.
-try:
- from . import git
- from . import rtems
- import error
- import git
- import path
- import rtems
+from rtemstoolkit import rtems
# Default to an internal string.
@@ -254,4 +248,8 @@ def revision():
return _revision
- print('Version: %s' % (str()))
+ print('Version : %s' % (version()))
+ print('Revision : %s' % (revision()))
+ print('Released : %s' % (released()))
+ print('Version control: %s' % (version_control()))
+ print('Version string : %s' % (string()))
diff --git a/tester/rt/check.py b/tester/rt/check.py
index f2addbd..39ee90d 100755
--- a/tester/rt/check.py
+++ b/tester/rt/check.py
@@ -1118,97 +1118,106 @@ class builder:
log.notice('Profile(s): %s' % (', '.join(profiles)))
self.run_jobs(self.profile_jobs(profiles))
+class settings(object):
+ def __init__(self):
+ self.opts = None
+ self.mail = None
+ self.args = argparse.ArgumentParser()
+ self.args.add_argument('--prefix',
+ help = 'Prefix to build the BSP.',
+ default = rtems.default_prefix(),
+ type = str)
+ self.args.add_argument('--rtems-tools',
+ help = 'The RTEMS tools directory.',
+ type = str)
+ self.args.add_argument('--rtems',
+ help = 'The RTEMS source tree.',
+ type = str)
+ self.args.add_argument('--build-path',
+ help = 'Path to build in.',
+ default = 'bsp-builds',
+ type = str)
+ self.args.add_argument('--log',
+ help = 'Log file.',
+ default = 'bsp-builer-%s.txt' % (_now().strftime('%Y%m%d-%H%M%S')),
+ type = str)
+ self.args.add_argument('--warnings-report',
+ help = 'Report the warnings to a file.',
+ type = str,
+ default = None)
+ self.args.add_argument('--failures-report',
+ help = 'Report the failures to a file.',
+ type = str,
+ default = None)
+ self.args.add_argument('--stop-on-error',
+ help = 'Stop on an error.',
+ action = 'store_true')
+ self.args.add_argument('--no-clean',
+ help = 'Do not clean the build output.',
+ self.args.add_argument('--profiles',
+ help = 'Build the listed profiles (profile,profile,..).',
+ type = str,
+ default = 'tier-1')
+ self.args.add_argument('--arch',
+ help = 'Build the architectures (arch,arch,..).',
+ type = str)
+ self.args.add_argument('--bsp',
+ help = 'Build the BSPs (arch/bsp,arch/bsp,..).',
+ type = str)
+ self.args.add_argument('--build',
+ help = 'Build name to build (see --rtems-config-report).',
+ type = str,
+ default = 'all')
+ self.args.add_argument('--jobs',
+ help = 'Number of jobs to run.',
+ type = str,
+ default = '1/%d' % (host.cpus()))
+ self.args.add_argument('--dry-run',
+ help = 'Do not run the actual builds.',
+ rtems.add_arguments(self.args, config_report_default = 'profiles')
+ mailer.add_arguments(self.args)
+ def parse(self, args):
+ self.opts = self.args.parse_args(args)
+ if self.opts.mail:
+ self.mail = mailer.mail(self.opts)
+ # Request these now to generate any errors.
+ self.mail_to_addr = self.mail.to_address()
+ self.mail_from_addr = self.mail.from_address()
+ self.mali_smtp_host = self.mail.smtp_host()
def run_args(args):
b = None
ec = 0
try:
rtems.clean_windows_path()
start = _now()
- prefix = '/opt/rtems/%s' % (rtems_version())
- tools = prefix
- build_dir = 'bsp-builds'
- logf = 'bsp-build-%s.txt' % (_now().strftime('%Y%m%d-%H%M%S'))
- config_file = rtems.bsp_configuration_file()
- argsp = argparse.ArgumentParser()
- argsp.add_argument('--prefix', help = 'Prefix to build the BSP.',
- type = str)
- argsp.add_argument('--rtems-tools', help = 'The RTEMS tools directory.',
- type = str)
- argsp.add_argument('--rtems', help = 'The RTEMS source tree.',
- type = str)
- argsp.add_argument('--build-path', help = 'Path to build in.',
- type = str)
- argsp.add_argument('--log', help = 'Log file.', type = str)
- argsp.add_argument('--config-report', help = 'Report the configuration.',
- type = str, default = None,
- choices = ['all', 'profiles', 'builds', 'archs'])
- argsp.add_argument('--warnings-report', help = 'Report the warnings to a file.',
- type = str, default = None)
- argsp.add_argument('--failures-report', help = 'Report the failures to a file.',
- argsp.add_argument('--stop-on-error', help = 'Stop on an error.',
- action = 'store_true')
- argsp.add_argument('--no-clean', help = 'Do not clean the build output.',
- argsp.add_argument('--profiles', help = 'Build the listed profiles (profile,profile,..).',
- type = str, default = 'tier-1')
- argsp.add_argument('--arch', help = 'Build the architectures (arch,arch,..).',
- type = str)
- argsp.add_argument('--bsp', help = 'Build the BSPs (arch/bsp,arch/bsp,..).',
- type = str)
- argsp.add_argument('--build', help = 'Build name to build (see --config-report).',
- type = str, default='all')
- argsp.add_argument('--jobs', help = 'Number of jobs to run.',
- type = str, default = '1/%d' % (host.cpus()))
- argsp.add_argument('--dry-run', help = 'Do not run the actual builds.',
- mailer.add_arguments(argsp)
- opts = argsp.parse_args(args[1:])
- mail = None
- if opts.mail:
- mail = mailer.mail(opts)
- # Request these now to generate any errors.
- from_addr = mail.from_address()
- smtp_host = mail.smtp_host()
- if 'mail_to' in opts and opts.mail_to is not None:
- to_addr = opts.mail_to
- else:
- to_addr = 'build at rtems.org'
- if opts.log is not None:
- logf = opts.log
- log.default = log.log([logf])
- log.notice(title())
- log.output(command_line())
- if mail:
- log.notice('Mail: from:%s to:%s smtp:%s' % (from_addr,
- to_addr,
- smtp_host))
+ settings_ = settings()
+ settings_.parse(args[1:])
config = rtems.configuration()
- config.load(config_file, opts.build)
- if opts.config_report:
- log.notice('Configuration Report: %s' % (opts.config_report))
- c_profiles = False
- c_builds = False
- c_archs = False
- if opts.config_report == 'all':
- c_profiles = True
- c_builds = True
- c_archs = True
- elif opts.config_report == 'profiles':
- c_profiles = True
- elif opts.config_report == 'builds':
- c_builds = True
- elif opts.config_report == 'archs':
- c_archs = True
- log.notice(config.report(c_profiles, c_builds, c_archs))
+ config.load(settings_.opts.rtems_config, settings_.opts.build)
+ config_report = config.report_args(settings_.opts)
+ if config_report:
+ report_type = settings_.opts.rtems_config_report
+ log.notice('RTEMS Configuration Report: %s' % (report_type))
+ log.notice(config_report)
sys.exit(0)
- if opts.rtems is None:
+ log.default = log.log([settings_.opts.log])
+ log.notice(title())
+ log.output(command_line())
+ if settings_.mail:
+ log.notice('Mail: from:%s to:%s smtp:%s' % (settings_.mail_from_addr,
+ settings_.mail_to_addr,
+ settings_.mail_smtp_host))
+ if settings_.opts.rtems is None:
raise error.general('No RTEMS source provided on the command line')
if opts.prefix is not None:
prefix = path.shell(opts.prefix)
@@ -1224,12 +1233,17 @@ def run_args(args):
'warnings-report' : opts.warnings_report,
'failures-report' : opts.failures_report }
- b = builder(config, rtems_version(), prefix, tools,
- path.shell(opts.rtems), build_dir, options)
+ b = builder(config,
+ rtems_version(),
+ settings_.opts.prefix,
+ settings_.opts.tools,
+ path.shell(settings_.opts.rtems),
+ settings_.opts.build_dir,
+ options)
- profiles = comma_split(opts.profiles)
- archs = comma_split(opts.arch)
- bsps = comma_split(opts.bsp)
+ profiles = comma_split(settings_.opts.profiles)
+ archs = comma_split(settings_.opts.arch)
+ bsps = comma_split(settings_.opts.bsp)
# The default is build a profile.
@@ -1251,7 +1265,7 @@ def run_args(args):
# Email the results of the build.
- if mail is not None:
+ if settings.mail is not None:
subject = '[rtems-bsp-builder] %s: %s' % (str(start).split('.')[0],
what)
t = title()
@@ -1278,7 +1292,7 @@ def run_args(args):
body += 'Warnings Report' + os.linesep
body += '===============' + os.linesep
body += b.results.warnings_report(summary = True)
- mail.send(to_addr, subject, body)
+ settings_.mail.send(settings_.mali_to_addr, subject, body)
print(gerr)
diff --git a/tester/rt/run.py b/tester/rt/run.py
index 1f4fa3a..aa192e0 100644
--- a/tester/rt/run.py
+++ b/tester/rt/run.py
@@ -164,9 +164,7 @@ def run(command_path = None):
except KeyboardInterrupt:
if opts is not None and opts.find_arg('--stacktrace'):
print('}} dumping:', threading.active_count())
- for t in threading.enumerate():
- print('}} ', t.name)
- print(stacktraces.trace())
+ print(stacktraces.trace('dump on exit', 'run', show_stacks = True))
log.notice('abort: user terminated')
sys.exit(1)
finally:
diff --git a/tester/rt/test.py b/tester/rt/test.py
index c5d61d8..c525396 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -394,9 +394,7 @@ def run(command_path = None):
killall(tests)
sys.exit(1)
2.15.1
