[PATCH] leon: do not use -mfix-{device} with Clang
Daniel Hellstrom daniel at gaisler.com
Fri Oct 5 06:57:49 UTC 2018
Clang do not support -mfix-gr712rc, -mfix-ut700 and -mfix-ut699.
Therefore we adjust the CPU_CFLAGS to remove these when compiling with
Clang. Instead use
  GR712RC:      -mcpu=gr712rc
  GR740:        -mcpu=gr740
  UT699/UT700:  Not currently supported by clang, use LEON3 BSP.
 bsps/sparc/leon3/config/gr712rc.cfg |  7 ++++++-
 bsps/sparc/leon3/config/gr740.cfg   | 23 ++++++++++++++++++++++-
 2 files changed, 28 insertions(+), 2 deletions(-)
diff --git a/bsps/sparc/leon3/config/gr712rc.cfg b/bsps/sparc/leon3/config/gr712rc.cfg
index 897dd01..3852932 100644
--- a/bsps/sparc/leon3/config/gr712rc.cfg
+++ b/bsps/sparc/leon3/config/gr712rc.cfg
@@ -8,7 +8,12 @@ RTEMS_CPU=sparc
 #  This contains the compiler options necessary to select the CPU model
 #  and (hopefully) optimize for it.
-CPU_CFLAGS = -mcpu=leon3 -mfix-gr712rc
+#  GCC and clang use different switches to select target:
+ifneq (,$(findstring clang,$(CC)))
+  CPU_CFLAGS = -mcpu=gr712rc
+else
+  CPU_CFLAGS = -mcpu=leon3 -mfix-gr712rc
+endif
 # optimize flag: typically -O2
 CFLAGS_OPTIMIZE_V = -O2 -g
diff --git a/bsps/sparc/leon3/config/gr740.cfg b/bsps/sparc/leon3/config/gr740.cfg
index 86da029..640a4fd 100644
--- a/bsps/sparc/leon3/config/gr740.cfg
+++ b/bsps/sparc/leon3/config/gr740.cfg
@@ -1 +1,22 @@
-include $(RTEMS_ROOT)/make/custom/leon3.cfg
+#  Config file for the LEON3 SPARC processor.
+include $(RTEMS_ROOT)/make/custom/default.cfg
+RTEMS_CPU=sparc
+#  This contains the compiler options necessary to select the CPU model
+#  and (hopefully) optimize for it.
+  CPU_CFLAGS = -mcpu=gr740
+else
+endif
+# optimize flag: typically -O2
+CFLAGS_OPTIMIZE_V = -O2 -g
+CFLAGS_OPTIMIZE_V += -ffunction-sections -fdata-sections
+LDFLAGS = -Wl,--gc-sections
2.7.4
