[PATCH] jffs, clang: avoid some warnings of used uninitialized ptr
Daniel Hellstrom daniel at gaisler.com
Fri Oct 5 13:33:57 UTC 2018
On 2018-10-05 14:01, Sebastian Huber wrote:
> On 05/10/2018 13:43, Daniel Hellstrom wrote:
>> On 2018-10-05 13:01, Sebastian Huber wrote:
>>> On 05/10/2018 12:44, Daniel Hellstrom wrote:
>>>> On 2018-10-05 09:41, Sebastian Huber wrote:
>>>>> On 05/10/2018 09:38, Daniel Hellstrom wrote:
>>>>>> On 2018-10-05 09:34, Sebastian Huber wrote:
>>>>>>> On 05/10/2018 09:25, Daniel Hellstrom wrote:
>>>>>>>> On 2018-10-05 09:12, Sebastian Huber wrote:
>>>>>>>>> On 05/10/2018 08:57, Daniel Hellstrom wrote:
>>>>>>>>>> This fixes the following test failures on LEON3 UP/SMP when
>>>>>>>>>> built using clang compiler:
>>>>>>>>>>   * fsjffs2gc01
>>>>>>>>>>   * jffs2_fserror
>>>>>>>>>>   * jffs2_fspermission
>>>>>>>>>>   * jffs2_fsrdwr
>>>>>>>>>>   * jffs2_fstime
>>>>>>>>> The problem is probably in the
>>>>>>>>> rbtree_postorder_for_each_entry_safe(). Coverity Scan has also
>>>>>>>>> an issue with this macro. It is on my todo list. Please do not
>>>>>>>>> check in this patch.
>>>>>>>> Ok I will not push it. Yes I was also thinking so. To use
>>>>>>>> offsetof() macro could be an option maybe, however the node
>>>>>>>> type input is not known to the
>>>>>>>> rbtree_postorder_for_each_entry_safe() function even though it
>>>>>>>> only used from jffs2 code.
>>>>>>> The Linux code uses typeof. We could do this also:
>>>>>>> diff --git a/cpukit/include/linux/rbtree.h
>>>>>>> b/cpukit/include/linux/rbtree.h
>>>>>>> index 53c777e8c1..8fc575240f 100644
>>>>>>> --- a/cpukit/include/linux/rbtree.h
>>>>>>> +++ b/cpukit/include/linux/rbtree.h
>>>>>>> @@ -126,12 +126,12 @@ static inline struct rb_node *rb_parent(
>>>>>>> struct rb_node *node )
>>>>>>>    for ( \
>>>>>>>      node = _RBTree_Postorder_first( \
>>>>>>>        (RBTree_Control *) root, \
>>>>>>> -      (size_t) ( (char *) &node->field - (char *) node ) \
>>>>>>> +      offsetof( __typeof__( *node ), field ) \
>>>>>>>      node != NULL && ( \
>>>>>>>        next = _RBTree_Postorder_next( \
>>>>>>>          &node->field, \
>>>>>>>        node != NULL \
>>>>>>> It shouldn't be a big problem since at least GCC and clang
>>>>>>> supports it. It is also a standard C++ operator. It is already
>>>>>>> used in
>>>>>>> cpukit/libfs/src/jffs2/include/linux/list.h
>>>>>> Ok, I will give it a try.
>>>>> Thanks, please try this patch:
>>>>> https://lists.rtems.org/pipermail/devel/2018-October/023181.html
>>>> Yes I can confirm it fixed all the 5 tests on gr712rc with clang.
>>>> It also removed the two warnings in jffs2 code related.
>>>> I have updated my patch to only include the third warning fix then:
>>>>  cpukit/libfs/src/jffs2/src/readinode.c | 2 +-
>>>>  1 file changed, 1 insertion(+), 1 deletion(-)
>>>> diff --git a/cpukit/libfs/src/jffs2/src/readinode.c
>>>> b/cpukit/libfs/src/jffs2/src/readinode.c
>>>> index 519b0d6..ecdf335 100644
>>>> --- a/cpukit/libfs/src/jffs2/src/readinode.c
>>>> +++ b/cpukit/libfs/src/jffs2/src/readinode.c
>>>> @@ -35,7 +35,7 @@ static int check_node_data(struct jffs2_sb_info
>>>> *c, struct jffs2_tmp_dnode_info
>>>>      struct jffs2_raw_node_ref *ref = tn->fn->raw;
>>>>      int err = 0, pointed = 0;
>>>>      struct jffs2_eraseblock *jeb;
>>>> -    unsigned char *buffer;
>>>> +    unsigned char *buffer = NULL;
>>>>      uint32_t crc, ofs, len;
>>>>      size_t retlen;
>>> What is this for a warning? Some sort of uninitialized variable
>>> warning? This code is identical to the Linux upstream. This is
>>> probably a clang bug.
>> buffer will never be uninitialized from what I see, so yes maybe its
>> a clang bug. This is the warning:
>> sparc-gaisler-rtems5-clang --pipe -DHAVE_CONFIG_H   -I..
>> -I/home/daniel/git/rtems/rcc-1.3/rtems/build/gr712rc_drvmgr_test_up/sparc-gaisler-rtems5/c/gr712rc/include
>> -I/home/daniel/git/rtems/rcc-1.3/rtems/kernel/cpukit/include
>> -I/home/daniel/git/rtems/rcc-1.3/rtems/kernel/cpukit/score/cpu/sparc/include
>> -I/home/daniel/git/rtems/rcc-1.3/rtems/kernel/cpukit/libnetworking
>> -I/home/daniel/git/rtems/rcc-1.3/rtems/kernel/c/src/../../cpukit/libfs/src/jffs2/include
>> -Wno-pointer-sign -mcpu=gr712rc -O2 -g -ffunction-sections
>> -fdata-sections -Wall -Wmissing-prototypes
>> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs
>> -MT src/jffs2/src/libjffs2_a-readinode.o -MD -MP -MF
>> src/jffs2/src/.deps/libjffs2_a-readinode.Tpo -c -o
>> src/jffs2/src/libjffs2_a-readinode.o `test -f
>> 'src/jffs2/src/readinode.c' || echo
>> '/home/daniel/git/rtems/rcc-1.3/rtems/kernel/c/src/../../cpukit/libfs/'`src/jffs2/src/readinode.c
>> /home/daniel/git/rtems/rcc-1.3/rtems/kernel/c/src/../../cpukit/libfs/src/jffs2/src/readinode.c:80:6:
>> warning: variable 'buffer' is used uninitialized whenever 'if'
>> condition is false [-Wsometimes-uninitialized]
>>         if (!pointed) {
> We have
> int pointed = 0;
> and the address of pointed is not taken, so this condition will be
> always true. I am not sure what the constraints of the
> -Wsometimes-uninitialized warnings are. Maybe they should trigger in
> case code modifications elsewhere might lead to the offending
> condition. Coverity Scan doesn't complain about this one.
> Please have a look at this patch:
> https://lists.rtems.org/pipermail/devel/2018-October/023190.html
> In contrast to the buffer = NULL initialization this patch entirely
> avoids the problematic path which must the compiler follow to deduces
> this warning.
It works too, the size and disassembly is the same in both cases with
clang (optimizations is turned on though). Apart from the code getting
harder to read, I believe it would break if __ECOS would be undefined
since pointed is used then. Maybe an #errror or an assert within the
#ifndef __ECOS should be added to signal that the code would break
otherwise.
/Daniel
