[PATCH 06/31] build: Merge libfdt/Makefile.am
Mon Oct 8 10:43:08 UTC 2018
 cpukit/Makefile.am            |  9 ++++++++-
 cpukit/configure.ac           |  1 -
 cpukit/dtc/libfdt/Makefile.am | 15 ---------------
 cpukit/wrapup/Makefile.am     |  1 -
 4 files changed, 8 insertions(+), 18 deletions(-)
 delete mode 100644 cpukit/dtc/libfdt/Makefile.am
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 7a3e8319ff..2ad1c1c425 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -23,6 +23,14 @@ libcpukit_a_SOURCES += dev/i2c/xilinx-axi-i2c.c
 libcpukit_a_SOURCES += dev/serial/sc16is752.c
 libcpukit_a_SOURCES += dev/serial/sc16is752-spi.c
 libcpukit_a_SOURCES += dev/spi/spi-bus.c
+libcpukit_a_SOURCES += dtc/libfdt/fdt_addresses.c
+libcpukit_a_SOURCES += dtc/libfdt/fdt.c
+libcpukit_a_SOURCES += dtc/libfdt/fdt_empty_tree.c
+libcpukit_a_SOURCES += dtc/libfdt/fdt_ro.c
+libcpukit_a_SOURCES += dtc/libfdt/fdt_rw.c
+libcpukit_a_SOURCES += dtc/libfdt/fdt_strerror.c
+libcpukit_a_SOURCES += dtc/libfdt/fdt_sw.c
+libcpukit_a_SOURCES += dtc/libfdt/fdt_wip.c
 libcpukit_a_SOURCES += sapi/src/chainappendnotify.c
 libcpukit_a_SOURCES += sapi/src/chaingetnotify.c
 libcpukit_a_SOURCES += sapi/src/chaingetwait.c
@@ -96,7 +104,6 @@ all-local: generate-vc-key
 # librtemscpu
 _SUBDIRS = . score rtems posix
-_SUBDIRS += dtc/libfdt
 _SUBDIRS += libcrypt
 _SUBDIRS += libcsupport libblock libfs
 _SUBDIRS += libdrvmgr
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index df9ee8c05b..0120bc193b 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -474,7 +474,6 @@ RTEMS_AMPOLISH3
 AC_CONFIG_FILES([
 Doxyfile
 Makefile
-dtc/libfdt/Makefile
 rtems/Makefile
 score/Makefile
 score/cpu/Makefile
diff --git a/cpukit/dtc/libfdt/Makefile.am b/cpukit/dtc/libfdt/Makefile.am
deleted file mode 100644
index 012923861d..0000000000
--- a/cpukit/dtc/libfdt/Makefile.am
+++ /dev/null
@@ -1,15 +0,0 @@
-include $(top_srcdir)/automake/compile.am
-noinst_LIBRARIES = libfdt.a
-libfdt_a_SOURCES =
-libfdt_a_SOURCES += fdt_addresses.c
-libfdt_a_SOURCES += fdt.c
-libfdt_a_SOURCES += fdt_empty_tree.c
-libfdt_a_SOURCES += fdt_ro.c
-libfdt_a_SOURCES += fdt_rw.c
-libfdt_a_SOURCES += fdt_strerror.c
-libfdt_a_SOURCES += fdt_sw.c
-libfdt_a_SOURCES += fdt_wip.c
-include $(top_srcdir)/automake/local.am
diff --git a/cpukit/wrapup/Makefile.am b/cpukit/wrapup/Makefile.am
index a24550da5a..014018349a 100644
--- a/cpukit/wrapup/Makefile.am
+++ b/cpukit/wrapup/Makefile.am
@@ -13,7 +13,6 @@ TMPINSTALL_FILES = $(PROJECT_LIB)/librtemscpu.a
 librtemscpu_a_SOURCES =
 TMP_LIBS =
-TMP_LIBS += ../dtc/libfdt/libfdt.a
 TMP_LIBS += ../score/cpu/@RTEMS_CPU@/libscorecpu.a
 TMP_LIBS += ../score/libscore.a
 TMP_LIBS += ../libcpukit.a
2.16.4
