[PATCH 14/31] build: Merge libgnat/Makefile.am
Mon Oct 8 10:43:16 UTC 2018
 cpukit/Makefile.am         |  8 +++++++-
 cpukit/configure.ac        |  1 -
 cpukit/libgnat/Makefile.am | 10 ----------
 cpukit/wrapup/Makefile.am  |  4 ----
 4 files changed, 7 insertions(+), 16 deletions(-)
 delete mode 100644 cpukit/libgnat/Makefile.am
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index f8fa627b1a..5b8a53a8c5 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -478,6 +478,13 @@ libcpukit_a_SOURCES += libdrvmgr/drvmgr_unregister.c
 endif
+if LIBGNAT
+libcpukit_a_SOURCES += libgnat/ada_intrsupp.c
+libcpukit_a_SOURCES += libgnat/adasupp.c
+endif
 if LIBNETWORKING
 libcpukit_a_SOURCES += libfs/src/nfsclient/proto/mount_prot_xdr.c
@@ -529,7 +536,6 @@ _SUBDIRS += libpci
 _SUBDIRS += libi2c
 _SUBDIRS += libmisc
 _SUBDIRS += libmd
-_SUBDIRS += libgnat
 _SUBDIRS += libstdthreads
 _SUBDIRS += wrapup
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 24a7228c67..7d93780fb2 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -497,7 +497,6 @@ score/cpu/v850/Makefile
 score/cpu/x86_64/Makefile
 score/cpu/no_cpu/Makefile
 posix/Makefile
-libgnat/Makefile
 libnetworking/Makefile
 libpci/Makefile
 librpc/Makefile
diff --git a/cpukit/libgnat/Makefile.am b/cpukit/libgnat/Makefile.am
deleted file mode 100644
index 87adb67ccd..0000000000
--- a/cpukit/libgnat/Makefile.am
+++ /dev/null
@@ -1,10 +0,0 @@
-include $(top_srcdir)/automake/compile.am
-if LIBGNAT
-noinst_LIBRARIES = libgnat.a
-libgnat_a_SOURCES = ada_intrsupp.c adasupp.c
-endif
-include $(top_srcdir)/automake/local.am
diff --git a/cpukit/wrapup/Makefile.am b/cpukit/wrapup/Makefile.am
index 722cb5913d..84ebb7dd95 100644
--- a/cpukit/wrapup/Makefile.am
+++ b/cpukit/wrapup/Makefile.am
@@ -19,10 +19,6 @@ TMP_LIBS += ../libcpukit.a
 TMP_LIBS += ../rtems/librtems.a
 TMP_LIBS += ../posix/libposix.a
-if LIBGNAT
-TMP_LIBS += ../libgnat/libgnat.a
-endif
 TMP_LIBS += ../libstdthreads/libstdthreads.a
 TMP_LIBS += ../libmisc/libmonitor.a
2.16.4
