[PATCH 16/31] build: Merge libmd/Makefile.am
Mon Oct 8 10:43:18 UTC 2018
 cpukit/Makefile.am        | 10 +++++++++-
 cpukit/configure.ac       |  1 -
 cpukit/libmd/Makefile.am  | 14 --------------
 cpukit/wrapup/Makefile.am |  4 ----
 4 files changed, 9 insertions(+), 20 deletions(-)
 delete mode 100644 cpukit/libmd/Makefile.am
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index e39d68cb54..dbd9e0f1a9 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -362,6 +362,8 @@ libcpukit_a_SOURCES += libfs/src/rfs/rtems-rfs-rtems-utils.c
 libcpukit_a_SOURCES += libfs/src/rfs/rtems-rfs-shell.c
 libcpukit_a_SOURCES += libfs/src/rfs/rtems-rfs-trace.c
 libcpukit_a_SOURCES += libi2c/libi2c.c
+libcpukit_a_SOURCES += libmd/md4.c
+libcpukit_a_SOURCES += libmd/md5.c
 libcpukit_a_SOURCES += sapi/src/chainappendnotify.c
 libcpukit_a_SOURCES += sapi/src/chaingetnotify.c
 libcpukit_a_SOURCES += sapi/src/chaingetwait.c
@@ -497,6 +499,13 @@ libcpukit_a_SOURCES += libfs/src/nfsclient/src/xdr_mbuf.c
 endif
+if SHA
+libcpukit_a_SOURCES += libmd/sha256c.c
+libcpukit_a_SOURCES += libmd/sha512c.c
+endif
 # Create a new Version VC Key header if the VC state has changed.
@@ -535,7 +544,6 @@ _SUBDIRS = . score rtems posix
 _SUBDIRS += libnetworking librpc
 _SUBDIRS += libpci
 _SUBDIRS += libmisc
-_SUBDIRS += libmd
 _SUBDIRS += libstdthreads
 _SUBDIRS += wrapup
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 38b677b21e..edc2ac9410 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -501,7 +501,6 @@ libnetworking/Makefile
 libpci/Makefile
 librpc/Makefile
 libmisc/Makefile
-libmd/Makefile
 libstdthreads/Makefile
 zlib/Makefile
 telnetd/Makefile
diff --git a/cpukit/libmd/Makefile.am b/cpukit/libmd/Makefile.am
deleted file mode 100644
index ce502f2265..0000000000
--- a/cpukit/libmd/Makefile.am
+++ /dev/null
@@ -1,14 +0,0 @@
-include $(top_srcdir)/automake/compile.am
-if NEWLIB
-noinst_LIBRARIES = libmd.a
-libmd_a_SOURCES =
-libmd_a_SOURCES += md4.c
-libmd_a_SOURCES += md5.c
-if SHA
-libmd_a_SOURCES += sha256c.c
-libmd_a_SOURCES += sha512c.c
-endif
-endif
-include $(top_srcdir)/automake/local.am
diff --git a/cpukit/wrapup/Makefile.am b/cpukit/wrapup/Makefile.am
index 6aeb657f83..3771f9b010 100644
--- a/cpukit/wrapup/Makefile.am
+++ b/cpukit/wrapup/Makefile.am
@@ -66,10 +66,6 @@ TMP_LIBS += ../librpc/librpc.a
 TMP_LIBS += ../librpc/libxdr.a
 endif
-if NEWLIB
-TMP_LIBS += ../libmd/libmd.a
-endif
 librtemscpu.a: $(TMP_LIBS)
 	$(AM_V_GEN)rm -f $@
 	$(AM_V_GEN)$(MKDIR_P) $(ARCH)
2.16.4
