[PATCH 18/31] build: Merge librpc/Makefile.am
Mon Oct 8 10:43:20 UTC 2018
 cpukit/Makefile.am        | 47 +++++++++++++++++++++++++++++++++++++++++++-
 cpukit/configure.ac       |  1 -
 cpukit/librpc/Makefile.am | 50 -----------------------------------------------
 cpukit/wrapup/Makefile.am |  2 --
 4 files changed, 46 insertions(+), 54 deletions(-)
 delete mode 100644 cpukit/librpc/Makefile.am
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 6f0cb1dcfa..3bfaa6b38b 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -496,6 +496,51 @@ libcpukit_a_SOURCES += libfs/src/nfsclient/src/nfs.c
 libcpukit_a_SOURCES += libfs/src/nfsclient/src/rpcio.c
 libcpukit_a_SOURCES += libfs/src/nfsclient/src/sock_mbuf.c
 libcpukit_a_SOURCES += libfs/src/nfsclient/src/xdr_mbuf.c
+libcpukit_a_SOURCES += librpc/src/rpc/auth_none.c
+libcpukit_a_SOURCES += librpc/src/rpc/auth_unix.c
+libcpukit_a_SOURCES += librpc/src/rpc/authunix_prot.c
+libcpukit_a_SOURCES += librpc/src/rpc/bindresvport.c
+libcpukit_a_SOURCES += librpc/src/rpc/clnt_generic.c
+libcpukit_a_SOURCES += librpc/src/rpc/clnt_perror.c
+libcpukit_a_SOURCES += librpc/src/rpc/clnt_raw.c
+libcpukit_a_SOURCES += librpc/src/rpc/clnt_simple.c
+libcpukit_a_SOURCES += librpc/src/rpc/clnt_tcp.c
+libcpukit_a_SOURCES += librpc/src/rpc/clnt_udp.c
+libcpukit_a_SOURCES += librpc/src/rpc/get_myaddress.c
+libcpukit_a_SOURCES += librpc/src/rpc/getrpcent.c
+libcpukit_a_SOURCES += librpc/src/rpc/getrpcport.c
+libcpukit_a_SOURCES += librpc/src/rpc/netname.c
+libcpukit_a_SOURCES += librpc/src/rpc/netnamer.c
+libcpukit_a_SOURCES += librpc/src/rpc/pmap_clnt.c
+libcpukit_a_SOURCES += librpc/src/rpc/pmap_getmaps.c
+libcpukit_a_SOURCES += librpc/src/rpc/pmap_getport.c
+libcpukit_a_SOURCES += librpc/src/rpc/pmap_prot2.c
+libcpukit_a_SOURCES += librpc/src/rpc/pmap_prot.c
+libcpukit_a_SOURCES += librpc/src/rpc/pmap_rmt.c
+libcpukit_a_SOURCES += librpc/src/rpc/rpc_callmsg.c
+libcpukit_a_SOURCES += librpc/src/rpc/rpc_commondata.c
+libcpukit_a_SOURCES += librpc/src/rpc/rpcdname.c
+libcpukit_a_SOURCES += librpc/src/rpc/rpc_dtablesize.c
+libcpukit_a_SOURCES += librpc/src/rpc/rpc_prot.c
+libcpukit_a_SOURCES += librpc/src/rpc/rtems_portmapper.c
+libcpukit_a_SOURCES += librpc/src/rpc/rtems_rpc.c
+libcpukit_a_SOURCES += librpc/src/rpc/rtime.c
+libcpukit_a_SOURCES += librpc/src/rpc/svc_auth.c
+libcpukit_a_SOURCES += librpc/src/rpc/svc_auth_unix.c
+libcpukit_a_SOURCES += librpc/src/rpc/svc.c
+libcpukit_a_SOURCES += librpc/src/rpc/svc_raw.c
+libcpukit_a_SOURCES += librpc/src/rpc/svc_run.c
+libcpukit_a_SOURCES += librpc/src/rpc/svc_simple.c
+libcpukit_a_SOURCES += librpc/src/rpc/svc_tcp.c
+libcpukit_a_SOURCES += librpc/src/rpc/svc_udp.c
+libcpukit_a_SOURCES += librpc/src/xdr/xdr_array.c
+libcpukit_a_SOURCES += librpc/src/xdr/xdr.c
+libcpukit_a_SOURCES += librpc/src/xdr/xdr_float.c
+libcpukit_a_SOURCES += librpc/src/xdr/xdr_mem.c
+libcpukit_a_SOURCES += librpc/src/xdr/xdr_rec.c
+libcpukit_a_SOURCES += librpc/src/xdr/xdr_reference.c
+libcpukit_a_SOURCES += librpc/src/xdr/xdr_sizeof.c
+libcpukit_a_SOURCES += librpc/src/xdr/xdr_stdio.c
 endif
@@ -567,7 +612,7 @@ all-local: generate-vc-key
 # librtemscpu
 _SUBDIRS = . score rtems posix
-_SUBDIRS += libnetworking librpc
+_SUBDIRS += libnetworking
 _SUBDIRS += libmisc
 _SUBDIRS += libstdthreads
 _SUBDIRS += wrapup
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index a1061f00b7..30b498ff3c 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -498,7 +498,6 @@ score/cpu/x86_64/Makefile
 score/cpu/no_cpu/Makefile
 posix/Makefile
 libnetworking/Makefile
-librpc/Makefile
 libmisc/Makefile
 libstdthreads/Makefile
 zlib/Makefile
diff --git a/cpukit/librpc/Makefile.am b/cpukit/librpc/Makefile.am
deleted file mode 100644
index 7cdcfd818b..0000000000
--- a/cpukit/librpc/Makefile.am
+++ /dev/null
@@ -1,50 +0,0 @@
-include $(top_srcdir)/automake/multilib.am
-include $(top_srcdir)/automake/compile.am
-if LIBNETWORKING
-man_MANS =
-noinst_LIBRARIES = libxdr.a
-libxdr_a_SOURCES = src/xdr/xdr.c src/xdr/xdr_array.c src/xdr/xdr_float.c \
-    src/xdr/xdr_mem.c src/xdr/xdr_rec.c src/xdr/xdr_reference.c \
-    src/xdr/xdr_sizeof.c src/xdr/xdr_stdio.c
-endif
-libxdr_mans = src/xdr/xdr.3
-if LIBNETWORKING
-man_MANS += $(libxdr_mans)
-noinst_LIBRARIES += librpc.a
-librpc_a_SOURCES = src/rpc/auth_none.c src/rpc/auth_unix.c \
-    src/rpc/authunix_prot.c src/rpc/bindresvport.c src/rpc/clnt_generic.c \
-    src/rpc/clnt_perror.c src/rpc/clnt_raw.c src/rpc/clnt_simple.c \
-    src/rpc/clnt_tcp.c src/rpc/clnt_udp.c src/rpc/get_myaddress.c \
-    src/rpc/getrpcent.c src/rpc/getrpcport.c src/rpc/netname.c \
-    src/rpc/netnamer.c src/rpc/pmap_clnt.c src/rpc/pmap_getmaps.c \
-    src/rpc/pmap_getport.c src/rpc/pmap_prot.c src/rpc/pmap_prot2.c \
-    src/rpc/pmap_rmt.c src/rpc/rpc_callmsg.c src/rpc/rpc_commondata.c \
-    src/rpc/rpc_dtablesize.c src/rpc/rpc_prot.c src/rpc/rpcdname.c \
-    src/rpc/rtime.c src/rpc/svc.c src/rpc/svc_auth.c src/rpc/svc_auth_unix.c \
-    src/rpc/svc_raw.c src/rpc/svc_run.c src/rpc/svc_simple.c \
-    src/rpc/svc_tcp.c src/rpc/svc_udp.c src/rpc/rtems_portmapper.c \
-    src/rpc/rtems_rpc.c
-endif
-librpc_mans = src/rpc/bindresvport.3 src/rpc/getrpcent.3 src/rpc/publickey.3 \
-    src/rpc/rpc.3 src/rpc/rpc_secure.3 src/rpc/rstat_svc.8 \
-    src/rpc/des_crypt.3 src/rpc/getrpcport.3 src/rpc/publickey.5 \
-    src/rpc/rpc.5 src/rpc/rstat.1 src/rpc/rtime.3
-if LIBNETWORKING
-man_MANS += $(librpc_mans)
-endif
-## FIXME: Unused
-include $(top_srcdir)/automake/local.am
diff --git a/cpukit/wrapup/Makefile.am b/cpukit/wrapup/Makefile.am
index 1b301bc119..6002cae21e 100644
--- a/cpukit/wrapup/Makefile.am
+++ b/cpukit/wrapup/Makefile.am
@@ -58,8 +58,6 @@ TMP_LIBS += ../libmisc/libxz.a
 if LIBNETWORKING
 TMP_LIBS += ../libnetworking/libnetworking.a
-TMP_LIBS += ../librpc/librpc.a
-TMP_LIBS += ../librpc/libxdr.a
 endif
 librtemscpu.a: $(TMP_LIBS)
2.16.4
