[PATCH 2/6] or1k/shared/cache/cache.c: Remove unused methods
Mon Oct 8 13:26:43 UTC 2018
 bsps/or1k/shared/cache/cache.c | 35 -----------------------------------
 1 file changed, 35 deletions(-)
diff --git a/bsps/or1k/shared/cache/cache.c b/bsps/or1k/shared/cache/cache.c
index 55fa54e..e664aec 100644
--- a/bsps/or1k/shared/cache/cache.c
+++ b/bsps/or1k/shared/cache/cache.c
@@ -96,30 +96,6 @@ static inline void _CPU_OR1K_Cache_instruction_block_lock
 /* Implement RTEMS cache manager functions */
-static void _CPU_cache_flush_1_data_line(const void *d_addr)
-  ISR_Level level;
-  _ISR_Local_disable (level);
-  _OR1K_mtspr(CPU_OR1K_SPR_DCBFR, (uintptr_t) d_addr);
-  //__asm__ volatile("l.csync");
-  _ISR_Local_enable(level);
-static void _CPU_cache_invalidate_1_data_line(const void *d_addr)
-  ISR_Level level;
-  _OR1K_mtspr(CPU_OR1K_SPR_DCBIR, (uintptr_t) d_addr);
 static void _CPU_cache_freeze_data(void)
   /* Do nothing */
@@ -130,17 +106,6 @@ static void _CPU_cache_unfreeze_data(void)
   /* Do nothing */
-static void _CPU_cache_invalidate_1_instruction_line(const void *d_addr)
-  ISR_Level level;
-  _OR1K_mtspr(CPU_OR1K_SPR_ICBIR, (uintptr_t) d_addr);
 static void _CPU_cache_freeze_instruction(void)
   /* Do nothing */
1.8.3.1
